Results 1 to 10 of 17
Thread: Drive train noise.
    84 Post(s)
    Drive train noise.
    G,day all, I have had a second hand gear box put in the Old Trol, and it still makes a clanging noise while rolling in the lower gears. The noise is not as bad, and the mech reckons the tail shaft and unis are ok. I was wondering if the old transfer case could damaged the diff, because of the excessive back lash, at all, because I put a GU diff in it last year.
    Below was Alitis007s reply in the Angry thread...... Thought it best go in here Mudnut, hope you don't mind.
    "There is no way that i am aware of that a transfer case can wreck a diff, happy to be proven wrong but i doubt it. What are the unis like in the tailshaft??"
  3. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    Alitis007 (30th August 2013), mudnut (30th August 2013)
    84 Post(s)
    I am not being too picky, am I. The noise gets worse when in low range, as the drive train smacks back and forth. Does any one else's Patrol make that type of noise? I' m gunna go to bed as the whole situation is doing my head in....
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    would it be an engine mount broken????
  6. The Following User Says Thank You to 93patrol For This Useful Post:
    Mine doesn't make a noise but over the last week of so there's been this rumble feeling that's been getting worse and can only feel it at really low speeds and it feels like it's coming from the middle of the car so I suspect transfer or my auto. But I'm gotta get under it on the weekend and give everything a greasing, will check my engine mounts for any play too.
  8. The Following User Says Thank You to Clunk For This Useful Post:
  9. #6
    Dec 2012
    Bunbury
    hmm could be your driveshaft has dropped a weight or you have a bulge in a tyre
  10. The Following User Says Thank You to 93patrol For This Useful Post:
  11. #7
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    We had a noise coming from the centre of the Maverick that got quite bad thought it was a handbrake issue, but was found to be a seized Uni joint on the tail shaft. Convinced it was the brake, the way we checked was to remove the tail shaft select 4H and drive a short distance, noise gone so it only left the tail shaft. we replaced both uni joints.
  12. The Following 2 Users Say Thank You to Pezzer For This Useful Post:
    Clunk (30th August 2013), mudnut (30th August 2013)
  13. #8
    cant see how a transfer case can stuff a diff,
    4x4 do have a lot of slop in the drivetrain,
    Have you chipped a tooth on the diff maybe
  14. #9
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    If be checking the backlash in the rear diff. Park it on a level surface with the handbrake off and turn the rear tail shaft back and forwards. It does help to have an idea on what's acceptable or not.
  15. The Following User Says Thank You to Parksy For This Useful Post:
  16. #10
    84 Post(s)
    This morning, it crunched and ground badly into second gear. It did it two more times, until the oil warmed up. I took the Old Trol to another mech, who put it on the hoist. He tried the tail shaft and said the backlash wasn't too bad. I then drove to ..... and let the sales bloke that I was a LITTLE PUT OUT, and got him to agree, that the old gear box is mine (a minor victory). He is going to come out to my place tomorrow, to listen to the crunchy box, and then check with the mech, what oil was used. I'm hooking up the trailer and picking up the old box, before I pay what is owed on the box.
  17. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    BigRAWesty (30th August 2013), Clunk (30th August 2013)
