Results 1 to 10 of 16
Thread: Got the boost gauge rattle
    Advanced Nvd323's Avatar
    Jun 2013
    Perth , WA
    Hi all.
    Im really over the boost gaugue rattle in my GU. I've tryed putting a damper in the vac line which helped but its still there. The question is what gauge do i get that is deffinitly not going to rattle and wont break my bank.
    Cheers Ryan
    Gold coast QLD
    Howdy I have a auto meter Cabot it's been installed for about 18mths and has not missed a beat would recommend them def no noise .... I was told the noise was from a leak but not sure ... My hose from intercooler pipe to gauge is the small hard plastic type ...
    2005 gu ZD30 3.0 Auto, Dobinson 2inch springs/shocks/firestone air bags, provent 200, EGR blocked, dawes valve, needle valve, snorkel, EGT,boost and trany temp gauge, torque converter lock up kit,Tunit chip, 2.75inch exhaust , ARB cage roof rack
    22 Post(s)
    I have boost and oil on the right hand side of the instrument cluster, the gauges are kn pods and the are velcroed to the dash, together and to the a pillar, havent moved in 3 years
    96 GQ coil/Cab
    08 G6eT
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    Buy a digital one then it won't rattle
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
  5. #5
    Jun 2013
    Perth , WA
    Hey that's true didn't think of a digital one that's and idea. Any one using VDO ? A mate of mine had one seems to good. My gauge isn't designed for the diesel motor that's y I'm getting the rattle and Major bouncing of the needle at idle...
  6. #6
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    I take it that it's a mechanical gauge with a hose from the engine? If that's the case then the hose acts like a stethoscope and the gauge just amplifies the noise in the cabin. It's worse when using copper hose, but apparently putting a loop in the hose before it enters the cabin can help.
  7. #7
    Jun 2013
    Perth , WA
    Yeahhh mech gauge plastic line. Yeah did read that while searching google. I dont think I've left enough hose though ill go buy rubber line tomorrow or might just get a auto meter gauge for diesel boost
  8. #8
    Nov 2012
    Coffs Harbour, NSW
    If you're on a budget like me I bought a digital boost gauge from repco when they had the sale $39, it's for a petrol but that doesn't matter to me as it just sits on 0 when not on boost....
    Cheers,
    Eric.
    1998 GU RD28T: RIP
  9. #9
    Jun 2013
    Perth , WA
    Cheers trekster ill check that out tomorrow are they 52mm?
  10. #10
    Nov 2012
    Coffs Harbour, NSW
    Quote Originally Posted by Nvd323 View Post
    Yeah mate and they are on special again!
    http://catalogues.repco.com.au/offer...urce=catalogue
    They come with their own map sensor and you just hook it all up and away you go!
    1998 GU RD28T: RIP
  11. The Following User Says Thank You to trekster For This Useful Post:
    Nvd323 (30th August 2013)
