Results 1 to 9 of 9
Thread: Compression
    Advanced filthyrich's Avatar
    Aug 2013
    yarra ranges melbourne
    Compression
    G'day awwl,
    Im currently looking to buy a GQ 93 petrol 4.2 from a good friend. The twist is, that the "head" apparently needs a recon. The theory for this is its running on gas (HOT) and the compression is down from the cylinders when measured... But! the compression is equal across all six pots. No water in the oil. Advise from back yard mechanic is that the valve seats drop into the boiling hot cylinder head thus not giving a good seal with the valve. ?? Or maybe the bore's have worn....but equally?? across all 6??
    Thought i'd throw it out thier, see if anyone else has seen or experienced this.
    Thanks for reading
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Sounds to me that the engine is just tired and in need of a freshen up. Rings, head and what ever else is worn. The story you were told sounds like bs.
  3. The Following User Says Thank You to Parksy For This Useful Post:
    filthyrich (24th August 2013)
    Legendary happygu's Avatar
    Gas does run hotter, and does wear out the valves themselves and their valve seats, especially if they aren't made for it.
    The valve seats don't drop as such, but it may just need a reconditioned / new head to be on it's way again.
    It would want to be fairly cheap, or in otherwise fantastic condition to take it as is, as it will normally cost you a little more than you think to get it up to spec....
    Mic
    Ballarat, Vic
    176 Post(s)
    Others with more recent experience or better memory than me might confirm, but I seem to recall that the way to tell of compression is down due to ring/bore wear or valves is to squirt a little oil into the cylinder & then test compression. If it improves with the oil it indicates ring/bore wear. if no different - indicates valve leak.
    Cuppa
  6. The Following User Says Thank You to Cuppa For This Useful Post:
    cgm (25th August 2013)
    I know nothing on such matters but I do know I'm not a fan of duel fuel. Fro. What I've read and heard, it seems to be more trouble than its worth. If you get the car cheap enough, if it were me I'd fix it up and rip out the gas system, stick to petrol. Yes they're thirsty beasts but we didn't buy them because they were frugal.
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Beg to differ mate as my Dual Fuel performs great on both Petrol & Gas with very little difference in Performance across both Fuels.
    Always kept well tuned and a Tank of ULP through every 4 tanks on Gas
    I have had about 4 Patrols on Dual Fuel over the years and I am still a Fan
    Have heard some horror stories though.
    My Son in Law has a 4.2 which has 580,000 on the Clock and has been run on Gas since new
    Regards
    Bob
  9. The Following User Says Thank You to Bob For This Useful Post:
  10. #7
    Aug 2013
    Thankyou very much for your replies guys. Yes from what i can see the cat has done very little off road use if any. The valves if just need lapping etc head skim/gasket should be cheap enough. ill give it a whirl myself. The cars is priced at $3500 au but thinking $3000. i have tried to look for "what to look for when buying a GQ" on here but failed. tried for some time too. Anybody see anything like that on here?
    Once again guys thanks for your input
  11. #8
    Apr 2011
    Melton
    If you need to do the head - bank on $1200 - $1500
    Look for rust - rear quarter panels, radiator support, fire wall.
    Check body mounts - they fail / crack the floor
    Take for a drive any wobbles ( you could also jack the front wheels and see if there is any movement - 12 / 6 o'clock push backwards and forwards = swivel & wheel bearing - 3 & 9 o'clock are wheel bearing
    What are the tyre like if you have a spare it must be road worthy, have a jack etc
    If the seats have holes put a cover over
    Does the steering wheel rubber have any movement - vehailes have been failed road worthy for this
  12. #9
    Aug 2013
    Thanks for the heads up Tank. I bought the car yesterday. went over all items mentioned above and the car came up top marks. thanks for your advise.
