Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: Reverse Camera advice please
  1. #31
    Bumped::::::::: been trying different camera positions to get the best view,
    found the best spot was on the alloy step directly above the tow bar, it is protected from knocks
    by my rear hook, has any one else mounted a camera here, I can pop rivet a piece of flat alloy
    on top of step to protect camera better,
    A mate of mine has his there and he made a little cage type thing that bolts where your hook is to protect it. It's in a great spot.
  2. #32
    @ REX is it instant when you select reverse,
    I was going to go through the double din head unit, I'm not sure with
    these units if it comes on straight away or do I have to select
    something, which wastes time
    My father-out-law has his hooked up to his double din jobby and screen comes on as soon as he shifts into reverse...... Don't know how it's connected as he had it done by some car stereo place.
  3. #33
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    Same place I have mine, Only thing I can fault is if I had a trailer on I couldn't see what it was doing.
    Only reason I mounted mine down there was that it is a big camera and wouldn't really fit anywhere else!
    Cheers,
    Eric.
    1998 GU RD28T: RIP
    1996 GQ RD28T: RIP 11 days later
    Hello 2012 GU CRDZD30
    Nissan winchbar + Warn, Dual Battery/Redarc, UHF and Titan rear drawers
  4. #34
    Ok huge thread dig here but wife has steamed ahead and purchased a flush mount button style camera..
    I have 3 options.
    I was going to mount it in the bumper but the steel chassis rail is mm's behind the bumper. .
    So I can try and find an opening or drill threw (no not ideal).
    Option 2..
    Drill a hole in the large door skin in under the tyre so it's directly above the tow ball???
    Or option 3 grab a mounted camera and do as you guys have.
    Opinions ??
    You could fashion a plate off the spare wheel holder that will hang below the tyre save drilling a good door.
    A small hole in the centre of the door with a rubber grommet is what they did to mine.
    Got a pic of the camera???
  6. #36
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
    threedogs (20th January 2016)
  8. #37
    Jan 2014
    Shepparton VIC
    kallen,
    Mine is not like yours, but a camera on a tiny steel plate
    I have mine mounted under the top of number plate trim (next to number plate light)
    The vision is covered a fair bit of by the spare wheel, but only close-by, I still can see a wide area about 10 feet away so I can judge on the reversing.
    The reason I didn't go closer to the bumper is, I was a bit worried in sunlight blocking the camera as the angle becomes less and less (camera more or less parallel to the floor).
    I would suggest you to try different places first before drilling around the back of the car.
    Cheers.
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  9. #38
    That style camera may limit you this style will go most places
    even next to the rear door latch if you want
    http://www.ebay.com.au/itm/Waterproo...0AAOSwKtlWjGiI
    Check your camera first to see if the image is grainy or not some are shite ?
  10. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (20th January 2016)
  11. #39
    Jan 2014
    Shepparton VIC
    Also check in all lighting conditions. I am surprised to see my camera's performance at night.
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  12. The Following User Says Thank You to MyGU8 For This Useful Post:
  13. #40
    Check your camer first to see if the image is grainy or not some are shite ?
    Yes I'm liking this style of camera.
    One of the members did an install and used it.. very professional I think
