Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Self sufficient
    Expert florix's Avatar
    Casino
    Self sufficient
    I am planing on getting my rig setup to be self sufficient so today my ground anchor turned up to add to my kit (winch extension strap, snatch strap, tree trunk protector, snatch block, shackles, tool kit, compressor and deflator, shovel and high lift jack, axe, long handle pruners and a work light)
    What other items do you recommend? Apart from extinguisher, which is coming soon. Oh and bog paper which keep forgetting to put in the car.
    ImageUploadedByMotorculture1377046407.285752.jpgImageUploadedByMotorculture1377046414.610112.jpg
    Try to have things that have more than one purpose,
    What do you mean by self sufficient ??
    Casino
    Meaning that if I happen to be alone I can get out/ through/over and have everything I need to get out of trouble. I know the list is endless but I mean more of necessities if you say pop a bead or tyre. Get stuck/ bogged have electrical issues and so on
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    A chainsaw maybe.
    Tyre repair kit.
    Jump starter pack or solar trickle charge.
    An epirb for just incase
    Hello from Under Down Under!
  5. The Following 3 Users Say Thank You to taslucas For This Useful Post:
    BigRAWesty (21st August 2013), outback (23rd August 2013), Stropp (21st August 2013)
    A chainsaw maybe.
    Tyre repair kit.
    x2 chainsaw for sure
    83 Post(s)
    Some wooden blocks for packing.(Use number two is emergency firewood). And a range of nuts and bolts. (needed a nut when the panhard popped off the axle)
    A purpose built {length} rachett strap to help seal popped bead, 9mtr of herc alloy draig chain. Jacking plate[s]
    One item I've found invaluable is a garden Hoe, great for dragging mud from around and under your 4x4,compressor
    Fiskar x27 axe. all sprays WD40 etc, fuses to suit, ground sheet, safety glasses ,work gloves, as you said the list is endless
    but if ppl keep naming stuff you could cull from that.
    FIRST AID KIT A GOOD ONE
  10. #8
    When we did the Madigan Line we were a long way from any where or anything! f you did not have the means to fix, repair, or replace you abandoned.
    Satellite Phone
    24 Volt Welder
    Spare Fuel Filter
    Bead Breaker
    Full set of Belts and Hoses for YOUR Car
  11. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (21st August 2013), florix (21st August 2013)
  12. #9
    Radiator flakes or similar, oils
  13. #10
    Casino
    Thanks everybody. Yeah I have a first aid kit and forgot to mention the tyre repair kit.
    I have a Father's Day present of a dual battery system too so will a jump starter be needed?
    Next time I change my belts I will be keeping them in the back of the car
    I also have a bolt bucket in the shed that has been a savior for many things.
    Was thinking a chainsaw but I went for the old fashioned approach as its lighter and easier to carry
