I am so stoked, it goes awesome and fuel economy I got 12.6L/100 on the way home which is a huge improvement. The fuel pump is my limiting factor now, it's maxed out! Boost at 16psi,he said in the summer if my EGTs are a bit high I should turn the boost up a little but other than that there is no point because it will not make more power. EGTs are the same as when they went in, so stoked again! Blue line is before, black is after.
And look what else came in the mail today, it's been a good day!
Alitis007 (20th August 2013), MudRunnerTD (20th August 2013), taslucas (20th August 2013)
Was meant to put this in that last post....
Alitis007 (20th August 2013), rusty_nail (20th August 2013)
Good stuff Winnie. Now for this...
I told you so!. awesome results mate it would be so much nicer to drive now too. Now enjoy mate.
Winnie (20th August 2013)
Well done mate. ... I hate you but you knew that !!!!
rusty_nail (20th August 2013), Winnie (20th August 2013)
Look at all the work you're doing for me. I should come over more often!
Hello from Under Down Under!
Oh yeah matt! It's seriously awesome, I am so stoked. Cannot thank you and benny enough for all your information!
Andrew said that the fuel pump has a bit of play in the shaft so needs some work... Maybe an upgrade??? Not for a while.....
I'll give this a try out on the weekend.
