Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Gq gauges
  1. #21
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Good idea, I never actually thought of that! Haha.
    Hello from Under Down Under!
  2. #22
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    I've bought myself a mechanical oil pressure gauge and some copper hose to suit, I was thinking of just removing the factory sender unit. Will this give me error codes on the computer? What size is the oil sender thread?
  3. #23
    Aug 2011
    North West Tas
    56 Post(s)
    You could just put a T piece in where the sender is that way could have the original gauge and the mechanical gauge
  4. The Following User Says Thank You to taslucas For This Useful Post:
    Parksy (16th August 2013)
  5. #24
    I have been too scared to go much below 1/4 tank because it's so incorrect above that I have no idea what left. I'll get 450-470kms before it hits 1/4 and when I fill up its around 70L
  6. The Following User Says Thank You to Winnie For This Useful Post:
  7. #25
    334 Post(s)
    So you have 25lt left which is Heaps mate. even on a bad day you have still got 150kms in the tank! My GQ has a fuel light too. I reckon your gauge sounds right mate if you have that much left and those kms.
  8. #26
    334 Post(s)
    Thats what i have done and run both gauges. Both electric gauges and works great. The after Market is way more sensitive than the factory too.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  10. #27
    Jan 2013
    Nowra NSW
    5 Post(s)
    Anyone heard of the tee piece breaking off because of the size of the original sender unit? That's my only issue with running the tee fitting. What size is the thread?
  11. #28
    Apr 2011
    Melton
    Re Gauge resistance:- At full 4.3 ohms. At empty 74.3 -84.8 ohms.
    The set up for the gauge is basically a voltage divider - 2 resistor in series with a meter measuring the voltage at the junction of the 2. (one of the resistors is the tanke gauge)
    I'm, using an ardunio microprocessor to display my LPG tank level - a estimate of distance left base on 24/l per 100k (i.e. 39l = 159Km) - also I had to average out the readings as the gauge jumps on bumps.
    See the photo of the display and board - I have no added a Temp sensor - battery level sensor - and playing with a O2 senor at the moment.
    Plus I now have set up a dimming control - as It was very bright at night time.
  12. The Following User Says Thank You to GQ TANK For This Useful Post:
    Parksy (18th August 2013)
  13. #29
    Jan 2013
    perth hills
    Best way to check gauge is drain the tank at home then put back in 10 or 20lt and check gauge reading. Then you will know that at x reading you have 20lts left in tank !!
    cheers Tim
  14. The Following User Says Thank You to silverbak For This Useful Post:
    Parksy (22nd August 2013)
