Page 13 of 16 FirstFirst ... 1112131415 ... LastLast
Results 121 to 130 of 151
Thread: Thirsty's 4.5L GU
  1. #121
    Expert Thirsty's Avatar
    Oct 2011
    Raceview, Ipswich QLD
    A bit of a break down on what it cost me!!!!!
    Motor,gearbox,bolt ons and wiring - $3000
    Marks adapter - $2300
    Sump -$600
    Genie extractors - $500
    Fuel pump and reg - $200
    Rebuild gearbox - $2334
    Radiator and Thermo fans - $1120
    Custom Airbox, Snorkel and overfow tank - approx $2000 Booked to be done on 29/7
    Power Steer Hose - $120
    Shifter -$289
    New Plugs and Leads - $220
    Lokka Dipstick - $90
    Exhaust - $850
    Ceramic coating - $270
    Brake line heat wrap - $21
    Wiring, Vats Removal - Killa Kustom Kables - $760
    New PCV Hose - $90
    Mod Plate - $240
    O2 Sensors - $90
    Misc Bolts,Oils,Coolant, senders and hoses - Approx $900
    Truck for towing to Exhaust shop $120
    Sub Total $14 194
    I still have to get new aircon lines made and have it gassed -approx $500, get it tuned - $800, New front bump stops and 30mm bumpstop spacers - $220
    Total $15 814
    Troy
    1998 GU TI LS1
  2. #122
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by Thirsty View Post
    That is a list you don't show the missus when you ask to do a engine conversion!!!!!
    Do you mind if I copy your cost breakdown over to the new Conversion thread Troy???
  3. #123
    Oct 2011
    Go for it mate.
    1998 GU TI LS1
  4. The Following User Says Thank You to Thirsty For This Useful Post:
    NissanGQ4.2 (14th July 2013)
  5. #124
    Oct 2011
    Progress on the airbox and snorkel
    1998 GU TI LS1
  6. #125
    Oct 2011
    1998 GU TI LS1
  7. #126
    Are you running an electric water pump?
    There used to be a guy John Bennet [retired] who enhanced OE water pumps from using pi$$y little pressed steel fans to using actual impellors.
    He also had parts made to house the thermostat in the bottom hose. I hope I can find all his Paper work, this same guy designed the cooling systems on the V8 race cars.
    He may have a web site not sure but a very talented guy with heaps of knowledge gone to waste. I had one of his systems on my cast iron 350 chev 4x4, you could idle all day with the aircon on,
    that's how good his system was, He had systems to suit motor HP motors
  8. #127
    Oct 2011
    No, it's all standard
    1998 GU TI LS1
  9. The Following User Says Thank You to Thirsty For This Useful Post:
    threedogs (10th August 2013)
  10. #128
    Aug 2013
    nice clean patrol, I like the v8 touch. It would bee more drivable now with the 8.
  11. The Following User Says Thank You to tezzza88 For This Useful Post:
    Thirsty (12th August 2013)
  12. #129
    Oct 2011
    Thanks Tezza. Its definately a different car to drive.
    Troy
    1998 GU TI LS1
  13. #130
    Oct 2011
    A bit of an update. I had a fuel reg failure. That's what happens when but a cheap copy. So I have now replaced it with the orginal aeromotive fuel reg. I have also booked it in for a mafless tune @ power torque engines on the 6th of September. So I'll see how good she goes and hopefully improve the shift patterns in the auto. I have also had it all engineered and rego changed to suit.
    Troy
    1998 GU TI LS1
