Hey, George, what can be done to toughen up the gearbox to make it handle the extra ponies from the upgraded engines?
A bloke from one of the gearbox and parts suppliers reckons my troll has exactly the same as a VL, when I gave him the VIN. So I may be able to upgrade the guts to the MX7,yeah?
Yeah, it would be sweet as, but the wallet is gunna be anaemic after whacking the secondhand box and trans case and new heavy duty clutch in. I will be doing up the old box when funds permit.
mudnut (11th August 2013)
yes!!!!!!!!! im waiting to hear back about an R31 wreck with good motor but rooted radiator unlicensed $300, and a vl commadore licesed $800
im quite confidant that when i get home in 10 days i will have the donor.
so i would really like a "how to" thread or link to help me do it
'92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
Lukey 2.5" Performance Exhaust with Extractors, snorkel
Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
im planning on just changing the head and the components not the whole engine
if i dont need to change the head then even better
The head is the same vl na and turbo , r31 and patrol. The cam is the only difference between carby, efi and efi turbo. The series 1 vl block dont have the tubo oil feed and drain or water line under the extractors but the series 2 and all r31's do. If you want to turbo the motor a series 2 (mid 87-88) vl loom is better coz it has the extra wire needed to wire up a knock sensor already in it. If your also going to run a turbo and are not going to get it engineered use the na pletnum chamber because it has bigger runners in it than the turbo one coz the turbo unit is from an rb20 sohc that the vl's and r31 use in nz, but we scored it coz of our awesome emission reg's. If you want to squeeze another 7kw out of the motor you can also get an XF EFI throttle body and match port the manifold to suite, but you dont feel the benefit coz its for top end performance.
Its not that hard to do just finding 20 yo parts that are in good working order is the problemi actually have a turbo set up that i used pieces from to do my vl turbo conversion on my old vl ex cop car that i had AND the na set up aswell lol
so i can leave the carby head on the rb30 and just attach the intake manifold etc.
if had my head off before i know it runs well
i was under the impression to go efi i would need an efi head?
