Results 11 to 20 of 27
Thread: Time to replace the dummy lights. Wiring colors?
    Where are we up to???
  2. #12
    Aug 2013
    I pulled the dummy's out today to have a look. It's all fairly straight forward.
    The hardest thing is going to be getting the globe holders to fit snugly.
    The wiring for reverse will be coming from the lhs. Stop & Parkers will need to come from the lights in the bumper. My lhs plug has only got the reverse and earth running to it unlike what I have seen described elsewhere. Red wire (reverse) black wire (earth)
    Also found out the 2 unused plugs visible from the lhs access panel are for the rear air con unit in the more st-l & TI.
    Has anyone found a practical use for these?
  3. #13
    Patrol Guru Evo's Avatar
    Jun 2013
    Lost somewhere in my own head...
    3 Post(s)
    I ran all from the LHS.
    I had some 5 core trailer cable lying around that I ran from left to right.
    I also upped the brake light and park light fuses to 15A (up from 10A) and the indicators fuse to 10A (up from 7.5)
    No problems, all works a treat!
    Evo
    Cheers,
    Evo
  4. #14
    You could put one of these behind the red and clear lens,
    As my previous post great output for reversing. And positive
    off/on brake effect, I've replaced every globe for led
  5. #15
    Aug 2013
    Just wired up the reverse ligh
  6. #16
    Aug 2013
    My biggest concern was dust from the drill bit getting inside the lense. Decided to melt out the centre with a soldering iorn: ImageUploadedByMotorculture1376306097.123047.jpg once it was neat enough the narva globe holder fit straight in. ImageUploadedByMotorculture1376306156.037443.jpg next I tapped in to the yellow pos wire from the existing reverse light using a wire splice. I ran the connection under the boot trim cover in to the access panel, under the jack stand then in to the space for the light.
    For earth I tapped in to the bumper lights from under the car.
  7. #17
    Aug 2013
    ImageUploadedByMotorculture1376306583.221849.jpgdropped the earth wire down through the grommet then hooked it up to the neg for the stop/tail/indicate: ImageUploadedByMotorculture1376306649.337859.jpg (black wire in above photo.
    Soldered the joins to the holder then wrapped with heat shrink. (Heat shrink goes on first :#)
    Slotted the globe holder in to the space cut in the reflector then sealed it up with some sikaflex.
    Replaced the cover, the two bolts and she's done.
    Works a treat and I can actually see when I reverse now!
    Will definitely be changing the globes to led and doing stop/tail one day but I'm in no hurry.
    More important as the next job is the double rear wheel mounted reverse lights/work light and antenna holder.
    Thanks again for all the help fellas. Will post up a finished product shot tomorrow.
  8. #18
    Aug 2013
    334 Post(s)
    Quote Originally Posted by Money-fishing View Post
    When your ready to do the rest will you swap over the brake signal out of the reverse lights and into the brake slot? Wow they must be bloody bright for the guy behind at night when you put your brakes on and the reverse lights come on? He'll sh1t himself !
  10. #20
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    It's not just the brake lights and reverse light on..... it's also the number plate lights, so the park lights are on as well.
