Results 1 to 6 of 6
Thread: What is this pipe?
    Advanced Maxgq's Avatar
    Mar 2013
    nunawading, Vic
    What is this pipe?
    Whats that pipe coming from the back of the turbo? not the exhaust, the small one
    *TD42* 2 inch suspension, 2 inch body, dts turbo, 3 inch exhaust, twin lockers, bighorns
  2. The Following User Says Thank You to Maxgq For This Useful Post:
    BigRAWesty (9th August 2013)
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Is it a dump pipe?
    Hello from Under Down Under!
    Legendary Alitis007's Avatar
    15 Post(s)
    Thats the screamer pipe, it connect to the wastegate
  5. The Following 2 Users Say Thank You to Alitis007 For This Useful Post:
    Maxgq (12th August 2013), taslucas (9th August 2013)
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Quote Originally Posted by Alitis007 View Post
    Correct, basically how a wastegate works is , when a certain (max) boost pressure is reached, boost pushes a diaphragm that in turn opens a valve, this valve (the wastegate valve) is held closed by a spring, and when pushed open, releases exhaust gas that is normally forced through the turbine housing of the turbo.
    The effect is to divert exhaust gas so it will bypass the turbine , and thus NOT continue to drive the turbo and generate boost once the max desired pressure is reached, in factory turbo cars this wastegate gas is fed back into the exhaust system for silent and legal operation.
    For less exhaust flow interuption, and maximum performance, some people with race cars, opt to not plumb the wastegate gas back into the ehaust system and disturb flow, instead, they just vent it straight to atmosphere, this allows for a more exact exhaust design, and a minimal performance improvement, but such direct wastegate venting of exhaust, creates a loud noise through such a short un-muffled pipe, hence the term "screamer pipe".
  7. The Following 4 Users Say Thank You to 04OFF For This Useful Post:
    AB (9th August 2013), Alitis007 (9th August 2013), Maxgq (10th August 2013), YNOT (9th August 2013)
  8. #5
    Mar 2013
    nunawading, Vic
    Thanks for that! A bloke at cliffhanger has one, it sounds awesome.
  9. #6
    Beginner scott.a.green's Avatar
    Aug 2013
    Yep, definitely a wastegate dump pipe. Although a very large one!
