Results 11 to 20 of 25
Thread: Recovery Bridles (Equalising Straps) and understanding Sling Loads
    Quote Originally Posted by Shaun 4x4 View Post
    Still waiting for answer?
    ET has had a few things on his plate lately so hasn't been on much, if at all. You'll be better off maybe sending him a PM as these threads also get buried quickly
  2. #12
    Expert Shaun 4x4's Avatar
    Secrets
    Thanks for the reply.
    Yer i sent him one a month ago or so. But no reply.
    I just want one they look like the best bridal strap ive ever seen.
    I have found snatch straps with anti recoil straps now which ill be ordering very soon.
  3. #13
    Well written mate and spot on.
    As you said the pi you posted is a perfect setup. We can't always have perfect but if you get a 3-4m ES or rope and a sleeve it will be the best option.
    But remember the shackles. Ensure you always use the correctly rates shackles for the job.
    hi Shaun ask at your 4x4 shop they may stock them, as they are used more now with all the IFS 4x4 on the road,
    I designed a snatchem strap with that extra recoil strap about 6 years ago I think. Anyway if your local 4x4 shop
    don't stock them go to your Cable and sling shop, they will know what your talking about
    A good cable sling shop may even make one up for you out of SWR
  5. #15
    Secrets
    I don't get why th op wouldn't give the name of who makes them.
    BUT after a lot of searching...... I found them
    http://www.comsew.com.au/?page_id=59
  6. #16
    Its a common item now most 4x4 shops should stock them
  7. #17
    Secrets
    I will have a look. The only 4x4 shops close to me are arb endorsed shops. So doubt they will have them
  8. #18
    I would imagine they would.
    good luck
  9. #19
    477 Post(s)
    Yeah at a price to match too.
  10. #20
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
  11. The Following User Says Thank You to meh For This Useful Post:
    threedogs (11th August 2013)
