Page 29 of 52 FirstFirst ... 2728293031 ... LastLast
Results 281 to 290 of 517
Thread: Blocking the EGR Valve
  1. #281
    us poms are crap at cricket fracster's Avatar
    North West England.
    Ok, I have a blank on order for my 2.8 and will remove the butterfly. Question is, where and why do I need to fit a catch can please?
    It is now official, we are not quite so sh@t at cricket as we were! Rugby Union is a different matter.
  2. #282
    North West England.
    Sussed it, should have used the search function more thoroughly.
  3. #283
    Apr 2013
    I've seen where people have asked whether to block the EGR at the exhaust or the inlet. Why worry. I just took my entire system out. Block a few hoses. Throw the plumbing away.
    The inlet side is blocked with a self made plate (contemplating measuring boost at that point - any comments).
    The exhaust side is where I installed my pyrometer sensor. It's more accurate here than on the down pipe.
    I know it some states this might be considered a bit radical but with the plastic cover on who can see? And if you get tested you're going to have issues regardless.
    I have used it with and without the valve hooked into the ECU. Seems to make no difference although it is hooked up now.
    300K+ on the ZD30.
    I think the biggest advantage to blocking the EGR is the cleanliness of the engine oil. Before blocking the oil was black even immediately after an oil change. Since blocking it is a lot cleaner.
  4. #284
    Expert florix's Avatar
    Casino
    love this thread
  5. #285
    Jun 2013
    Great info, sure to carry out this mod while rebuilding the engine
  6. #286
    Apr 2013
    Well after 13 years of owning my 2.8 GU. I finally had the courage to block the EGR, remove the butterfly valve, and disconnected the charge air temperature sensor. The car is now performing much better
  7. #287
    Nov 2011
    Quote Originally Posted by the ferret View Post
    Here ya go mate.
    Is it crucial that the td42 EGR is blocked on the manifold side or can it be blocked underneath where the pipe fits on? My plate fits both.
  8. #288
    Quote Originally Posted by paps01 View Post
    Either is OK.
  9. #289
    Nov 2011
    Thanks mate.
  10. #290
    Oct 2013
    Perth
    Great thread
