Results 1 to 10 of 13
Thread: Where to purchase 2" lift for a y61 GU
    Sydney NSW
    Cool Where to purchase 2" lift for a y61 GU
    Wanting to do a 2" lift for the troll, need some help on finding the gear for it... I'm not into going to a shop and paying full price for it when their is other places or websites that have the same thing for a better price haha Does anyone have any places you's know? Located in sydney area
    Last edited by NissanGQ4.2; 12th September 2013 at 05:43 PM. Reason: Changed Title
    Expert Limmy's Avatar
    Ive been told the tough dog with 9 adjustable settings are good. U may get away not havin to get extended brake lines
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    If you can do the work yourself then check ebay, there are a few different brands for sub $1000 delivered, like king springs, lovells, tough dog, dobinsons etc
    http://goo.gl/sN8S1u
    1998 GU RD28T: RIP
    1996 GQ RD28T: RIP 11 days later
    Hello 2012 GU CRDZD30
    Nissan winchbar + Warn, Dual Battery/Redarc, UHF and Titan rear drawers
    Advanced Woodsta1704's Avatar
    Jun 2013
    Perth WA
    Mate check out http://4wd1.com/ They have Tough Dog suspension kits to suit most budgets. I ordered my 2" kit with foam cell shocks and air bags from them a couple of years ago. And any order over $100 is free freight.
    2002 GU 3 Lt Patrol Wagon. On Board Air, ARB Front Air Locker, 2"Tough Dog Lift, Rear Air Bags, Tracklander Roof Rack, IPF HID Spotties, K&N Air Filter, Cargo Barrier, 3" Dominator Exhaust, Titan Drawers and much more.
    Beginner Wayne P's Avatar
    Jun 2013
    Berwick Vic
    I have seen quite a lot on Ebay but I could not recommend which one's are any good. I will want to do the same to my 2007 Walkabout when I get it next week so I will monitor the responses you get here.
  6. #6
    I have 2" EFS and no problems at all, price should be around $800 IMO as you only need 4 x coil and 4 x shocks
  7. #7
    334 Post(s)
    Quote Originally Posted by Mattonpatrol View Post
    How much are you prepared to spend? What do you do with your car? How long do you want it to last?
    If you just want the cheapest lift you can get then grab a Blupac kit off eBay cheap. You get what you pay for though.
    If you have a decent budget then buy the best you can afford. You will only need 4 springs and 4 shocks. I assume you can fit them yourself?
  8. #8
    Expert Blacklotusdog's Avatar
    Zordos suspension, superior engineering and suspension stuff are all good vendors. Give them a call and discuss what you have, what you want to do with it and they will be able to recommend something suitable.
    OME from arb always get a good wrap and are valved for the patrol and Aussie conditions.
    If you can afford it the armada extreme remote res shocks get a really good wrap. They are about $275 a corner though.
    If you want extra flex Suspension Stuff flexy coils will allow you to fit longer shocks without your springs dropping out. Superior engineering also have a new linear rate coil that sounds very well designed.
    In the end as other have said it depends on what you plan on doing with your truck. Is it just a daily driver? Do you plan on loading up to gvm and touring long distance on corrugated outback roads? Is it a weekend warrior which your tackling rocky, rutted tracks in. Hard to give advice without more info, also worth doing a search on 2 inch lift as there is heaps of info out there already.
    My advice is work out what you want to do with car and how much your willing to spend at most then give the businesses I mentioned above a call and see what they recommend.
    2012 GU8 Polar White Auto ST Patrol, Factory Bull bar, Scangauge 2, EGR blanked, Milford cargo barrier, Outback ideas recovery points, Micks retrofit HID 3 inch projectors with Osram bulbs and 55w ballasts, GME TXE3420, Sidewinder dual battery with monitor, Windcheetah 2.0m alloy rack, Suspension Stuff 2" Flexy lift with SS Monotubes, MT ATZ 4 ribs 265/75R16 on black Dynamic rims, Custom rear draws with fridge slide.
  9. The Following User Says Thank You to Blacklotusdog For This Useful Post:
    NoRush (18th September 2014)
  10. #9
    Sydney NSW
    well i have a budjet of arond $1500, and am prepaid to pay for something very decent in a 2'' lift... i will also be doing work bymyself,, done it coupla times before...
  11. #10
    Expert Ronin's Avatar
    Brissy
    I got a 2" lift with Koni shocks, dobinson coils fitted for 1300.
    2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
