Results 1 to 10 of 20
Thread: Road tyre pressure?
    Beginner LocknLoad's Avatar
    Jul 2013
    Perth WA
    Road tyre pressure?
    Picked up a y61 GU9 from the dealership this week. They had 52psi all round. Seems a bit high. Thoughts?
    2013 GU9 Patrol Value Pack (stock)
    Jul 2013
    Perth WA
    Tyres are Bridgestone Duellers A/T
    Yea a bit mate. Most run 38-40 on the black top.
    Owner of
    Westy's Accessories
    Quote Originally Posted by LocknLoad View Post
    Way too high mate....... 35-38 I reckon would be just fine
    My folks went to the Google Play Store and all they got me was this lousy Motorculture App!!!!!!!
    82 Post(s)
    That's interesting. I find that the middle of the treads on my HT 31x10.5 15 wranglers chew out at anything above 28-30psi.
  6. #6
    My Mt atzs appear to be wearing evenly so far at the pressures I run them at
  7. #7
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    i run 40psi with my BFG AT
    ireckon run anything between 30 and 40 psi and see how it feels
    did you check the pressures cold or after you had been for a drive?
  8. #8
    40 psi for hwy, for max fuel economy
    35-38 psi around town
    Check the wheel nuts every other month as they do come loose
  9. The Following User Says Thank You to threedogs For This Useful Post:
    Safari Njema (8th August 2013)
  10. #9
    22 Post(s)
    What is the recommended pressure as stated on the tyre, it's no use just throwing figures if they are manufacturer specs
    96 GQ coil/Cab
    08 G6eT
  11. #10
    Expert Blacklotusdog's Avatar
    I run around 40 round hwy and town. 265/75r16 mt atz 4 rib, from what I can tell wearing evenly but only about 5000km on them so far.
    2012 GU8 Polar White Auto ST Patrol, Factory Bull bar, Scangauge 2, EGR blanked, Milford cargo barrier, Outback ideas recovery points, Micks retrofit HID 3 inch projectors with Osram bulbs and 55w ballasts, GME TXE3420, Sidewinder dual battery with monitor, Windcheetah 2.0m alloy rack, Suspension Stuff 2" Flexy lift with SS Monotubes, MT ATZ 4 ribs 265/75R16 on black Dynamic rims, Custom rear draws with fridge slide.
