Results 1 to 8 of 8
Thread: Drop box or super flex???
    Jul 2013
    Sunshine coast
    I've got 4inch lift in my gu n I'm experiencing wobbles at 80kph, pulling to the left yet the steering wheel is slightly right hand down... Steering wheel was at qtr turn n had 3shops try to adjust it n align it but still not happy... Got adj panhards n drag link... I've had a lot of opinions on what I should do... From bushes to drop boxes to super flex arms to some fancy offset bearings... Any ideas???
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    Did your 4 inch lift come with castor correction if it didn't you will need bushes drop boxes or super flex arms but a 80km wobble is kind of a patrol thing hopefully someone else has more info. Did te wobble start before or after the lift
    Such is the rule of honour.
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    How often do you go off road???
    Jul 2013
    Sunshine coast
    Offroad fairly often... yeah we done superior castor plates... Always pulled left n wobbled but I thought new susp would fix it... I've been told to do drop box n only one super flex on pass side n std on drivers???
  5. #5
    Aug 2010
    17 Post(s)
    I'm not going by personal experience just what I have read
    Castor correction - no good for anything over 3 inch lift
    Dropboxes - More bitumen than off road
    Superflex - more off road than bitumen
    I'm sure some of the guys with more experience will see your post soon and be able 2 help you out more
  6. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    macca86 (28th July 2013)
    Jul 2013
    Sunshine coast
    The bearing thing was to stop it pulling left... I'm not sure of the terminology but I will try my best to explain... It was at caloundra suspension n exhaust when I was quoted 600 to supply n fit.... The cradle or housing for the bearings is slightly egg shaped and thicker on one side than the other which as u rotate it the camber is slightly adjusted???? I dunno I'm a bloody plasterer not a mechanic... Also the back wheels are not tracking the same as front??? Is that adj through the panhard???
    Legendary happygu's Avatar
    Quote Originally Posted by Dave n xanths gu View Post
    That is adjustment of Panhards.
    I would go dropboxes, but that is me..... Reasoning is that it puts the diff and driveline closer to the factory settings, and the flex will be similar angles to factory too.
    Mic
    Feb 2011
    Shed
    45 Post(s)
    Drop boxes or extended arms if you got the coin, Doesn't have to be super flex arms there are others out there, unless you're after shiploads of flex then go the superflex. Yup the panhards adjust how its tracking at the rear also
  10. The Following User Says Thank You to growler2058 For This Useful Post:
    Dave n xanths gu (28th July 2013)
