Results 21 to 30 of 32
Thread: Water/Mud - What was I thinking?
    Patrol Guru Morton's Avatar
    Sydney West
    looks like you went in to hard, this throws to much water into the fan/cowling area & drops your revs & momentum, you should have made that easily if you where slower, creating the 'bow wave" which inhibits water & actually sucks you along giving you constant momentum & torque, but what the heck, we have all done it haha
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
  2. #22
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Quote Originally Posted by schanmala View Post
    Great write up mate. Good thing she's still running.
    Check the gearbox/diff oils.
    I blew my lux gearbox as the top seal wasn't sealed proplerly and water went in there. Drove it like that for a week then it went boom!
    Yep, both diffs and gearbox had to pumped out and flushed about 4 times before it looked pretty clean. I'll get them checked again next service as well.
    Sent from my GT-N7000 using Motorculture mobile app
    Thanks, Cameron
    No Patrol now - Just good memories!
  3. #23
    Jul 2012
    Ballarat
    Two comments about too much speed. Looks like it is obvious I'm a sand driver. Ha ha
    I'll have to keep it in mind for next time ...
    Thanks, Cameron
  4. #24
    Jul 2012
    Ballarat
    Hi Guys,
    Just a question about the winch after such a dunking of the car. I have a Warn XD9000 (fairly old, like 8+ years) and it wasn't used while I was submerged, but it was sitting in the muddy water for 20 minutes or so all up. Having seen the sludge that came out of the diffs I was wondering do I have to worry about doing any maintenance on the winch? Are they pretty well sealed normally?
    Obviously it would be easiest to stick my head in the sand and ignore it. It is a lot of work to pull the bar off to get the winch out, etc., but if I'm going to wreck it otherwise I guess I'll have to.
    Interested for some input from the experienced.
    Thanks,
    Cameron.
    Thanks, Cameron
  5. #25
    Quote Originally Posted by cgm View Post
    Hi Guys,
    Thanks,
    Cameron.
    A week or 2 to tear down and clean out, maybe a tube of grease and some minor parts..
    Or take the chance or a complete rebuild when Its all rusted inside..
    I'd tear down.. Best to be sure.
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
    cgm (8th September 2013)
  7. #26
    Jul 2012
    Ballarat
    Kallen's probably right, but giving this a bump, hoping that someone who regularly uses their winch in anger in the wet might reply (MR?).
    I assume they don't do maintenance every couple of weeks?
    Thanks, Cameron
  8. #27
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    give Mud runner a pm might be a good idea
  9. The Following User Says Thank You to 93patrol For This Useful Post:
  10. #28
    Legendary happygu's Avatar
    Well done Cameron,
    Loved the story...... and the pics ....
    I pull my winch down every couple of years and it is always perfectly clean and dry, but then I don't normally sit submerged for 20 minutes.
    I would check it out, just to be sure - you may be able to loosen off the bolts a little on the motor and gearbox and crack them open a little, to see if any moisture comes out - if it doesn't then it is up to you if you want to keep pulling it down.
    You can drop your winch out, without removing the bar too, by just removing the bottom bash plate.
    Mic
  11. The Following User Says Thank You to happygu For This Useful Post:
  12. #29
    Oct 2011
    Essendon
    Well that was just silly.... I would never attempt anything like that???? Ba ha ha ha ha!!!!!
    Oh the joys of temporary loss of common sense... well done!!!
    Yeah, what sort of idiot would do something like that? LMAO
    Tip tip tip......tap tap tap....
  13. #30
    Jul 2012
    Ballarat
    Quote Originally Posted by happygtu View Post
    Well done Cameron,
    Mic
    Thanks Mic. I'll see how hard it looks to get out without the bar coming off. Might be good to have a look inside anyway. Pretty sure this is the only time in its life it would have seen water. Very dry here. Having said that maybe the seals could be dry and not working.
    Guess I'm answering my own question really - just don't want to listen to myself.
    Thanks, Cameron
