Results 1 to 7 of 7
Thread: MAF SENSOR zd30ddti
    Expert Limmy's Avatar
    MAF SENSOR zd30ddti
    Hi Guys
    I managed to round the torx head screw on the maf sensor. tighten it too much last time . does Nissan sell these screws separately or do I need to purchase a whole maf sensor for the screws ?
    thanks!
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    You should be able to buy those screws from a good fastener supplier, you will need to take the old one to match the thread up.
  3. The Following User Says Thank You to trekster For This Useful Post:
    Limmy (12th July 2013)
    Just take a screw with you and go to bunnings. Who cares if I doesnt have the same screw head. As long as the thread is right.
    I tapped that app
  5. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Limmy (12th July 2013), trekster (12th July 2013)
    Nov 2012
    Coffs Harbour, NSW
    Just take a screw with you and go to bunnings. Who cares if I doesnt gave the same screw head. As long as the thread is right.
    I tapped that app
    I probably should have mentioned this also! You will be able to get the screw in a phillips or allen headed capscrew quite easily.
  7. The Following User Says Thank You to trekster For This Useful Post:
  8. #5
    yep I might do that. at least will be easy to take on and off during cleaning intervals
    thanks guys.
  9. #6
    Only tighten it up finger tight too. A hard finger tight. Too tight and you will strip the plastic thread. Also add a little grease around the o'ring to give it the extra seal.
    I tapped that app
  10. #7
    Yeah I have bad habit tightening nuts bolts too tightly.
