Results 1 to 7 of 7
Thread: ZD30DI viscous fan service
    Adelaide Hills, SA.
    Has anyone seen any information on servicing the viscous hub on the direct injection ZD30 - I'm told the viscous fan is attached to the water pump shaft? Does that mean you lose coolant pulling it off?
    cheers
    Mike
    Dec 2012
    Yes to replace the clutch fan, water pump comes off, it come as a assembly, I'v just recently done mine,
    What state are you from? I should be able to beat any prices youve been given.
    Rob,
  3. The Following User Says Thank You to SupRob For This Useful Post:
    Mikees (22nd May 2013)
    Thomastown, Melbourne
    6 Post(s)
    On the TB42 you can pull the fan off without disturbing the water pump... my fan seized up a few weeks ago so I just swapped it out from one off a donor car I have sitting here..
    Will service my other one as a back up.
  5. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Adelaide Hills, SA.
    Red face Help?
    Hi again, well it sounded easy in theory, but the cowling is off now and well .... not sure what to remove next. Have already removed a few things surplus to requirements, so don't want to make it too hard when putting it all back together. Any tips on what to remove next?
    Mike
    Dec 2012
    Hi Mike,
    When I did mine, I took out the alternater (To get the the thermostate) which loosed the belt, then took the whole waterpump out.
    Of course at this time I have no coolant/water in the system.
    As far as im aware they are not serviceable, brand new water pump including clutch fan should be no more then $250 pending brand..
    Rob,
  8. The Following User Says Thank You to SupRob For This Useful Post:
    Mikees (9th July 2013)
  9. #6
    reasonable price, I know you can buy the fluid from Toyota but being a TLCCV member never heard of
    patrol fans being serviceable. I'll do some checking
    EDIT,,,,,,,,,,,,My manual says fan coupling cannot be taken apart is described as non serviceable and should
    be replaced with the "F" mark facing the front
  10. #7
    Adelaide Hills, SA.
    reasonable price, I know you can buy the fluid from Toyota but being a TLCCV member never heard of patrol fans being serviceable.
    Thanks Threedogs, met a guy travelling who had split the coupling successfully and relubed it on his DI - so it can be done. I don't normally work on the car so I'm just fumbling around in the dark atm. Want to make sure I remove the right bits
