Results 1 to 10 of 10
Thread: TB42 carb blooding
    Advanced Dirk Diggler's Avatar
    Mar 2013
    TB42 carb flooding
    Hey guys..
    I'm in need of some advice about my TB42.
    Never had a problem with it until close to home the other night from work.. I could feel it start to run rough, cough splutter etc and when I pulled up to see what was going on I noticed that the carby had filled completely with fuel..
    A friend had suggested the float might have sunk? Could this be the case? And is this easy to get to/remove and repair?
    Cheers guys
    Is it dual fuel ???
    Mar 2013
    Sorry, no, petrol only
    I've heard many ppl change floats over to solid ones as a backfire etc may cause the float to implode.
    Wouldn't think a big job, some carbie cleaner, new gasket O'haul kit, workshop manual
  5. The Following User Says Thank You to threedogs For This Useful Post:
    Dirk Diggler (7th July 2013)
    84 Post(s)
    It could be as simple as bit of crap stuck in the needle and seat.
  7. The Following User Says Thank You to mudnut For This Useful Post:
    Mar 2013
    I'm plenty comfortable to work on efi systems but carbies scare me a little haha.. Is cleaning these an easy job to do??
  9. #7
    Apr 2011
    Melton
    A carby kit is not heard to do -
    Take a heap of photos before you pull the carby apart - handy when you are putting it back together.
    When you do it - lay newspaper out - so that you will catch any loose bits
    To flood its either the needle / seat, or the float stack
  10. The Following User Says Thank You to GQ TANK For This Useful Post:
  11. #8
    Mar 2013
    Thanks guys! I'll start pulling the carby off and get stuck into it
  12. #9
    84 Post(s)
    Good, someone with more experience has beaten me to the punch.
  13. #10
    Mar 2013
    Thanks for the advice lads! I pulled off the tophat on the carby, appears that the float may have been stuck down, it didn't move around too freely on it's pin. Fixed that, cleaned the needle and seat, cleaned out some debris from the float bowl and all is well..
    Let it idle for 15 mins, then took it for a run down the road and back, seems all good. Seems I've got some more power too! Something obviously wasn't right
    Cheers!
