Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Wheel bearing problem
    Advanced Ferret's Avatar
    Jul 2012
    Hey guys I was looking to see what I need due to differential oil getting into my wheel bearing what kit will I need to stop this from happening I have no idea on what I should be purchasing .... Do I get a wheel bearing kit will this have the gasket and all that stuff to stop that problem or does it fall into the swivel hub kit I don't have a clue on the differences as you can tell I probably not even making sense I'm that unsure off lol thanks guys all the help will be good .......
    mk patrol sd 33turbo diesel, bullbar, roof racks, driving lights, efs 2 inch lift, 35" Federals, Rear qtr chop.33" led lightbar..
    brisbane
    I think its the bearing kit but not 100% I'm sure someone will confirm however if funds permit.. Couldn't Hirt to do the swivel hub while your at it and replace diff oil at the same time while its apart.
  3. The Following User Says Thank You to megatexture For This Useful Post:
    Ferret (9th July 2013)
    X 2 with MT why not give the entire front end a birthday with new bearings, seals and fluids
  5. The Following User Says Thank You to threedogs For This Useful Post:
    Ferret (5th August 2013)
    Jul 2012
    i was thinking so to may aswell have a double bday with it thanks
  7. The Following User Says Thank You to Ferret For This Useful Post:
    GQ TANK (12th July 2013)
  8. #5
    Apr 2011
    Melton
    You have more then 1 seal leaking.
    The axle seal behind the cv - must be leaking to let diff oil into the cv. -
    The grease seal in front of the cv
    And the rear wheel bearing grease seal.
    How long have you had the problem - is the cv noisy when in 4wd?. Do you have wheel wobbles?
    Depending on how long the oil has been present - you might be looking at a wheel bearing kit, a king bearing kit and a CV. - ouch
    To test -
    CV - noisy in 4wd - clicking noise
    Wheel bearing noise
    jack the front wheel - grub the tyre at 12 - 6 puch backwards and forwards - movement - suspect king bearings - (can also be wheel bearing). Now hold the try at 3 & 9 push backwards and forwards - movement - loose or staffed wheel bearings.
  9. The Following User Says Thank You to GQ TANK For This Useful Post:
  10. #6
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Buy the combined king and wheel bearing kit, it's cheaper!
    1999 GU 4500 dual fuel
    Il dado è tratto
  11. The Following User Says Thank You to NP99 For This Useful Post:
  12. #7
    Apr 2011
    Melton
    I got mine from bursons as I could return what I did not use
  13. #8
    334 Post(s)
    Swivel hub rebuild kit combined with a Wheel Bearing kit will have a complete front end rebuild. All seals and all bearings.
    Terrain Tamer are a good brand. Replace the lot if your getting busy. Don't fit half the kit! Fit it all.
  14. #9
    334 Post(s)
    This is a bargain though and includes the swivel hub kit and the wheel bearings. You will require Grease and Rags and about 10 hours
    http://www.ebay.com.au/itm/Nissan-Pa...a6ceae2&_uhb=1
  15. #10
    Jul 2012
    yeh no cv noises pretty smooth in 4 wheel but defently wheel bearings are gone and id say those knuckle bearings are cactus lol muddrunner i was looking at that kit i think thats the option i guess for this old thanks guys learn somthing new everyday much appreciated
