Page 21 of 50 FirstFirst ... 1920212223 ... LastLast
Results 201 to 210 of 498
Thread: Outback Ideas Recovery points
  1. #201
    Quote Originally Posted by NP99 View Post
    TD, how does the rear point attach to the vehicle?
    It goes in place of the OEM hoop just above the rear step
    Tapping on the Tab via MC
  2. #202
    Apr 2013
    PM sent TD
  3. #203
    Expert Kast's Avatar
    Nov 2012
    Sydney, NSW
    Guys,
    I bought two front recovery points and the rear loop from John.
    Top quality (construction and finish), great pricing, quick delivery (melb to perth) and he's always quick to answer any queries and help.
    So, from me, you shouldn't buy anything else from anyone else. Unless you like paying through the nose for ordinary.
    Sent from my GT-I9305 using Tapatalk 2
    GU IV 2006 Snorkel 225 Driving Lights Dual Batteries Factory Bar Awning Rear Drawers Part NADS (so far)
  4. The Following User Says Thank You to Kast For This Useful Post:
    Avo (13th July 2013)
  5. #204
    John, would you recommend using your rear hoop for recoveries? I don't doubt the strength of the hoop, but it was bought up by another member that it is simply held on by the thread of 4 bolts, I would not trust it at all. Maybe for towing but not for recoveries. Like I said I'm sure the hoop itself is up for recoveries my concern is that it's only held on by the thread of 4 bolts.
    If you're happy and you know it tap a post!
  6. #205
    I have used it on my other 4x4 and this 4x4 plus made them for half a doz Comp trucks in Vic.
    Never had a problem, Maybe talk to your local bolt bloke on how threads grab/forces etc to get peace of mind.
    I do have backing plates in 6mm that after bolting on use the backing plate with Nyloc nuts .
    Originally they were made to go each side of the roller fairlead on Land Rovers, Then I noticed that most if not all 4x4
    had the 85 x45 bolt pattern on the rear. I've pulled cement trucks out of muddy drive ways , tojo S the lot.
    I'm very confident in it as are some mining companies. Hope it answers some queries you have. I use the Hook BTW not loop
    Edit::: Its actually the strongest one I make
  7. #206
    Yea Winnie being a rigger/ boilermaker the 4 bolts are plenty to hold that plate on..
    But like always make sure the chassis is up to scratch.
    Owner of
    Westy's Accessories
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
  9. #207
    I've found some GQs not a lot but some rust away at the front of chassis, where bog holes and bad cleaning has lead to the chassis failing.
    Most GQ and GUs Ive looked at, that rear section is pretty well rust free, as no area for mud to sit and do its thang.
  10. #208
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    3D do you use a backing plate and why a hook vs the loop?
    1999 GU 4500 dual fuel
    Il dado è tratto
  11. #209
    Just for different styles, I don't make hook one anymore Billy Bleed got last one.
    I like the hook for ease of use, and you'll find things don't fall up. As hook has no retaining clip.
    I like the loop as well cause its very very strong on its own and the M20 eye bolt one I call bush hoop.
    Edit No I dont use backing plate on my GU or the other one ooops
  12. #210
    I have to shout out a big thanks to Threedogs for his excellent service,sent a pm with a few questions regarding his recovery points that he makes all questions answered so I ordered,Cheers great service and the gear looks great too
    regards neil
