Results 1 to 10 of 15
Thread: Crunching gears
    Expert luke28's Avatar
    Crunching gears
    So my 3rd and 4th gear crunch it used to be just 3rd but now its 4th aswell if I double clutch going up gear its fine but crunches going down unless I've got the brake on a touch and the revs in a certain spot I've been told on here its probably the syncro rings or bar "cant remember what its called dont know much about it" anyway just wondering if I dont fix that is it going to do worse damage to my gearbox
    Sent from my IQ255 using Motorculture mobile app
    Pretty certain the sincromesh gears are shot..
    But if you keep crunching them they won't last.. when slowing use the engine as much as possible. Clutch and hold a slight pressure at the gear you wanna select and give it a good rev. It should slide in crunch free..
    By using the engine it saves your brakes to..
    Owner of
    Westy's Accessories
  3. The Following User Says Thank You to BigRAWesty For This Useful Post:
    luke28 (27th June 2013)
    I have to do that for reverse sometimes
    Have you checked your clutch fluid lately?
    Owner of
    Westy's Accessories
    Yeah just filled it when my clutch master buggered up
    Quote Originally Posted by luke28 View Post
    Bleed it? You may have some air in there and not throwing the clutch fully..
    Owner of
    Westy's Accessories
    I bled it 3 times when I replaced it just to make sure but it was crunching before that anyway
  9. #8
    No worries, just checking.. so yea, try not to crunch em..
    Owner of
    Westy's Accessories
    Ill try what you said but 4th allways catches a little going down
  11. The Following User Says Thank You to luke28 For This Useful Post:
    BigRAWesty (27th June 2013)
  12. #10
    Feb 2011
    Shed
    45 Post(s)
    Those clutch slaves are a major Effker to bleed properly man
    Sent from my iPhone using Motorculture mobile app
