Page 4 of 57 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 565
Thread: Parksy's gq
  1. #31
    Jun 2013
    Good stuff mate i had to do the same traded the v8 for a tuff family tourer
  2. The Following User Says Thank You to soronation For This Useful Post:
    Parksy (7th August 2013)
  3. #32
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Rebuilt the front calipers. Pulled them all apart, wire brushed them, then checked them in a molasses bath for a week. Came out almost like new. Painted in por15, re sealed and new hardware kit chucked on. Happy with the results.
  4. #33
    Jan 2013
    Nowra NSW
    5 Post(s)
    Haven't had much luck with the eBay alloy radiators, have killed 2 in the last 6 months so I've gone with an adrad copper/brass unit. Not sure if they died because of stray currents so I've purchased an analogue multi meter to test the system. Digital multimeters are no good for this test, but basically it's a matter of pulling the radiator cap off, negative probe onto the negative battery terminal and positive probe into the filler neck so it contacts the coolant but not any metallic parts, ie the filler neck. Shouldn't register a voltage of 0.05v or more, otherwise the radiator will have a shortened life span. Done with the engine running and all electrical items on, such as hazards, lights, radios. Etc. If a voltage of 0.05v or more is registered, turning off each electrical item one at a time may isolate the problem and get sorted from there. Just waiting for the multimeter to arrive so I can get to the bottom of this.
    Here's the new radiator(again but an adrad one at least)
    The 2nd alloy radiator
    The first alloy radiator
    Both leaked in similar fashion. I was lucky that they were replaced under warranty. Actually they just sent me new units. I ended up selling the 3rd when it arrived.
  5. #34
    How have you found those drilled/slotted disc rotors so far ???
    Are some pics out of whack as last pic of rotors they looked OE
  6. #35
    Jan 2013
    Nowra NSW
    5 Post(s)
    No pictures are correct. Only the rear rotors needed replacing so I changed these with the slotted rotors. The fronts are oe at the moment but I might change these shortly to the same rotors as when I did change the rears, braking performance had improved a lot. So they are recommended.
  7. The Following User Says Thank You to Parksy For This Useful Post:
    threedogs (14th August 2013)
  8. #36
    82 Post(s)
    Your rig looks really tidy, Parksy. Got to get it dirty sometime though.
  9. #37
    Jan 2013
    Nowra NSW
    5 Post(s)
    You're not wrong mudnut. But I have been fixing things up since I've bought it and it's a lot easier to work on when it's clean. Almost there though, have done too much to list now on it. I wish I could drive a brand spanking new gq so I could compare that to this one.
  10. The Following User Says Thank You to Parksy For This Useful Post:
    Bloodyaussie (14th August 2013)
  11. #38
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    How much did you pick the RDA slotted up for? need to do all 4 on mine while its off the road
  12. #39
    Jan 2013
    Nowra NSW
    5 Post(s)
    I think I paid around the 130 mark off eBay, without postage mind you. This was for the rears.
    Fronts are a little more, but not by much.
  13. The Following User Says Thank You to Parksy For This Useful Post:
    NissanGQ4.2 (17th August 2013)
  14. #40
    Aug 2013
    Looks Boss, very clean
