Page 184 of 1057 FirstFirst ... 182183184185186 ... LastLast
Results 1,831 to 1,840 of 10566
  1. #1831
    84 Post(s)
    Noticed the valves pinging a little, under hard acceleration, so I backed off the timing 4 degrees, and now it goes like a cut cat, dragging a brick, as per RB30 norm
  2. The Following User Says Thank You to mudnut For This Useful Post:
    BigRAWesty (24th June 2013)
  3. #1832
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    In cabin manual boost controller installed, Chucked a switch on my driving lights to finish them off as well.
  4. #1833
    Advanced Woodsta1704's Avatar
    Jun 2013
    Perth WA
    Replaced the Fan belt tensioner assembly on my ZD30 02 Patrol and chucked on a new belt too. (No more squealing now, thank christ lol)
  5. #1834
    Apr 2013
    Finally starting to put all the bolt on's in place..picked up the bullbar today...started late with putting in the 2' lift with new KM2's and so only got the front done ..ended up having to finish it by torch light !!
    Rear to be done tomorrow , superior panhard rod and bullbar ..starting to morph from stock to a truck...gotta love the look of 33's on it.
  6. #1835
    Patrol God Stropp's Avatar
    38 Post(s)
    Quote Originally Posted by Woodsta1704 View Post
    Mate lucky it's just the belt and not the dreaded grenade squeal!
  7. The Following User Says Thank You to Stropp For This Useful Post:
    BigRAWesty (30th June 2013)
  8. #1836
    38 Post(s)
    Took my mate out who is over from qld and showed him what a patrol can do cause the poor fella only has a jeep!
  9. #1837
    Took a big bite.. now I gotta chew..
    But also got the rods done.. new HD drag rod compared to old one.. 32mm compared to 25...
    Owner of
    Westy's Accessories
  10. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Parksy (30th June 2013)
  11. #1838
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Looks like you mean business westy.
    Had a win in the annoying rattles in cabin department. Applied silicone the top of the windscreen dimister ducts, which sit underneath the dash. Also used silicon on the ducting system underneath the dash, where lots of the ducting meets the external ducting, there's a join that has foam to take up the slack. Over 20 years of use and this foam is a little worse for wear. But the silicone does a good job of stopping the two joins making aweful noise when driving. Also applied a little lube to the steering column and the car just feels more solid. It's a nice feeling when the car doesn't rattle and make aweful noises.
    Also found a hole where the firewall joins the floor on both passenger and driver side. Looks like it came from factory with it. All sealed now. Was wondering why sometimes on wet days the floor felt damp... If anyone needs clarification on what I siliconed I'll be happy to explain in detail.
  12. #1839
    Yea that's the next thing on the list. Stripping the interior and sound proofing.
    Owner of
    Westy's Accessories
    Expert Shaun 4x4's Avatar
    Secrets
    Did my oil and filter today.
    Also finished mounting my compressor, tank and rear outlet.
    Just need a new AUX battery and i can test the system.
