Results 11 to 20 of 36
Thread: td42 light engine mods
    Perth
    Well if you not wanting to go to much I would look at a Garrett gtx2863, these can be had for about 1400 from the states but don't quote me on that, or a little dearer from a dealer over here. Throw a decent from mount intercooler on it and if your handy could do all that for 2-2500. With a nice tune this should get you about 130rwkw up from about the 90 it may have from stock. The torque increase will be the biggest but and drive ability will be much nicer.
    http://www.ebay.com.au/itm/Garrett-G...item232aef7cd0
  2. #12
    North brissy
    That's at the engine flywheel. By the time it gets to your back wheels (which is what I stated) you would be doing well I make 90-95kw.
    If you were to put the above figures back to the engine it would be up around the 160 mark
  3. #13
    North brissy
    That's a 3071 mate. Way to big for your setup. Check out ATP turbo
  4. #14
    Perth
    ok cool thats heaps anyway :P it was cheaper than the smaller one haha thanks for all this help mate
  5. #15
    Perth
    so with that turbo and new cooler u dont think need new pump or injectors?
  6. #16
    North brissy
    With the gtx2863 and front mount plus the low k's your rig has I wouldn't be to worried.
    If you wanted more power then a bigger pump and turbo would be required and you would get injectors done as well.
    Another good turbo that works well with the stock 11mm injector pump is a UFI TD05 18G but these will set you back around 2800 just for the turbo.
  7. #17
    Perth
    and do you not think i should not keep top mount even if i get a better one?
  8. #18
    North brissy
    That's up to you mate. There is plenty of info around on these types of forums.
    Top mounts get heat soak and to get one that works well (cross country) your looking at big dollars, water to airs work well but are a little complex (adding another cooling system) and front mounts are cheap and simple (plus you can work on the engine without anything in the way)
  9. #19
    Perth
    good point the more i think about it the more i just want to spend the bigger dollars
  10. #20
    North brissy
    Have a look on patrol4x4.com mate. There is bundles of info on there about this exact thing.
    Probably the best advice I can give you is read as much as you can on this subject and ask plenty of questions. Then make your decision take your time it can be very rewarding.
