Page 172 of 1057 FirstFirst ... 170171172173174 ... LastLast
Results 1,711 to 1,720 of 10564
  1. #1711
    Legendary happygu's Avatar
    Re doing my reverse light options, now instead of the 27 watt flood on top of my Faux wheel.
    I had another lid laser cut and recessed it to fit a small light bar. Trouble is all done now have
    to wait till Tuesday to get it powder coated, didnt think it through, even forgot to pick up my
    rear step as well. live and learn lol
    Where are you bringing your cables through for your rear light TD?
  2. #1712
    Advanced gokhangqtd42's Avatar
    Apr 2013
    Turkey/Antalya
    Hi guys,
    This week, my gq (td42) at:
    1.Yakıt pompası değişimi (remove the inline pump, VE pump wear)
    2.to td42, turbo installation did
    3.and new clutch....
    Ex : Lr 110"def+ Lr100" def+Tyt WX80 Land Cruiser+MB 406 Ünimog doka : Jawdrop:
    New: 1992 Nissan GQ y60 safari (td42) : Hpfredgeorge1:: Bananarock:
  3. The Following 3 Users Say Thank You to gokhangqtd42 For This Useful Post:
    mudnut (10th June 2013), Stropp (9th June 2013), threedogs (9th June 2013)
  4. #1713
    Apr 2013
    Turkey/Antalya
    Turbo fıttıng....
  5. The Following 3 Users Say Thank You to gokhangqtd42 For This Useful Post:
  6. #1714
    Apr 2013
    Turkey/Antalya
    new clutch
  7. The Following 2 Users Say Thank You to gokhangqtd42 For This Useful Post:
  8. #1715
    Advanced ShaunM's Avatar
    Dec 2012
    Hastings, VIC
    Wish I could say I fitted EGT and boost gauges...but can only say drilled a messy hole in my dump pipe.
    Was trying to tap a thread in for the fitting but stuffed it up. I'll have to find someone Tuesday morning to weld one on.
    The rest of it's almost done with no probs though.
  9. #1716
    Did you get it sorted.??
    Also going to cut some Laser plates to mount Fire extingishers in cab.
    The BEST Position is either in front or beside the driver.
    Reason being its the FIRST thing to grab in the advent of a fire.
    No point mounting them say on your cargo barrier, or cargo area
    Will be very cost effective, plus save you drilling into floor.
    Been thinking on this for a while.
    I'm still waiting for my IC to arrive thinking Tuesday everything is Tuesday
  10. #1717
    Patrol Guru
    Apr 2011
    Melton
    Replaced the clutch, (pulled the donk) as I wonted t replace the exhaust manifold gasket.
    Found the rear welch plug nearly cored though.
  11. #1718
    Patrol God Stropp's Avatar
    36 Post(s)
    Did 388 k's on the new long range tank and the gauge only moved to just below full
  12. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    Clunk (9th June 2013), Woof (9th June 2013)
  13. #1719
    Perth WA
    63 Post(s)
    Finally got The Q off road and dirty
  14. The Following User Says Thank You to Woof For This Useful Post:
  15. #1720
    Oct 2011
    Essendon
    Gave the Q a nice wash after a dirty weekend in the Howqua Hills.
    Tip tip tip......tap tap tap....
