Results 1 to 4 of 4
Thread: nads question?
    Jul 2012
    Pottsville
    nads question?
    have done the full nads 5months ago and is doing everything it should without any issue's. [good egt and no over boosting]question is should the battery been disconnected for an hour or so to reset ecu after this mod?
    3lt GU 111 Wagon 2 inch lift,3in Taipan exhaust, cross country intercooler,catch can,EGR blocked, dawes and needle valve,Pyro/boost gauge ARB lockers,steinbaurer chip, long range tank, s/s water tank, draws, warn winch, and other stuff.
    477 Post(s)
    Some say yes. I say no. I have never disconnected the battery after doing any of this work. Doesn't really matter if you do anyway. Only takes a minute.
  3. The Following User Says Thank You to mudski For This Useful Post:
    june (8th June 2013)
    Jul 2012
    Pottsville
    not that I have any problems, I will be leaving it alone. but for others that my want to disconnect their battery to reset things, how long a time? is it just minutes or a lot longer.
    Half an hour is fine as a clean of the Maf can be done at the same time.
