Results 1 to 4 of 4
Thread: Snatch Strap
    Expert Tonks's Avatar
    ACT
    Snatch Strap
    Whats the best way to join 2 snatch straps together if required .
    Using a rolled up news paper or mag. Try to avoid sticks and homemade things .
    In the event a strap breaks you have a missile .Can't put a pic here ATM either.
    Never tie together, basically thread one eye through the other and use rolled up newspaper
    to lock in place.
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Tonks (30th May 2013)
    Expert twisty's Avatar
    May 2011
    ACT
    Like this
    GU1 Auto ST4500 lpg/petrol.
  5. The Following 7 Users Say Thank You to twisty For This Useful Post:
    BigRAWesty (29th May 2013), mudnut (29th May 2013), MudRunnerTD (29th May 2013), scotty83 (29th May 2013), threedogs (29th May 2013), Tonks (30th May 2013), Wine_maker (29th May 2013)
    Expert Bulbous's Avatar
    Apr 2011
    Dubai
    Just to clarify - the rolled up newspaper/magazine is used to stop the two straps binding on each other and getting stuck together.
    If you ever try it without the paper - you will find that the two straps almost become welded.
    I've done it and in the end we had to cut the oldest strap away from the newest to salvage the new strap. Old one was destroyed
    Steve
    2011 Patrol Safari 4.8 (Fitek)
  7. The Following User Says Thank You to Bulbous For This Useful Post:
