Results 1 to 10 of 13
Thread: TB42E engine wiring diagrams
    Advanced Dirk Diggler's Avatar
    Mar 2013
    Hey guys..
    I'm just chasing a wiring diagram for the TB42E for an aftermarket ecu project.
    Through googling left me empty handed
    Would anyone be able to help me out?
    Kyle.
    Thomastown, Melbourne
    6 Post(s)
    Get to 25 posts mate and you can just download the manual... what ECU you looking at????
    Mar 2013
    Ahh righto cheers mate
    I have the Y60 manual however it doesn't have an EFI supplement, unless I am missing it.
    I'll keep on posting till then!
    6 Post(s)
    If you are really stuck ask Yendor for advice mate.... dont forget to share your experiance mate??
  5. #5
    Mar 2013
    Will do!
    Will be a Haltech, either PS1000 or Sprint 500
  6. The Following User Says Thank You to Dirk Diggler For This Useful Post:
    Bloodyaussie (27th May 2013)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Kyle we do not have the EFI supp. Good luck finding an electronic copy I don't think one exists. You can buy it online from various bookshops. If you do happen to come across one in electronic form please let us know
    Todd
  8. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    Aug 2010
    17 Post(s)
    Anything in particular you need to know???
  10. #8
    6 Post(s)
    Todd
    Well there ya go......... thanks Todd!!
  11. #9
    Mar 2013
    Nothing specific at this point in time, Still in planning. Motor is turning up next week.
    I am going from tb42 to tb42e. I have acquired the engine for next to free, its in good condition with low miles however it's lacking an ECU and distributor, comes with the full wiring harness...
    I figured I could spend $500 odd getting the parts I need to make it complete, and have the headf!ck of fitting the OEM loom, or I could spend $1500 odd and fit an aftermarket ecu, run LS1 coil packs, Ditch the airflow meter and run a MAP sensor instead. At this stage I am interested in turbocharging it, but have not decided on it 100% as yet.
    So with that in mind I'm trying to work out if I am better off to source an EFI dizzy to trigger the haltech or if I cap off the dizzy hole and use a trigger wheel and hall effect sensor off the harmonic balancer.. Thoughts?
    When I start doing all this i'll put up a thread in the builds section with as much detail as I can.
  12. The Following User Says Thank You to Dirk Diggler For This Useful Post:
  13. #10
    Aug 2010
    17 Post(s)
    Send a PM to Jeff ( WhiteGQ )
    I'm not 100% certain but I think his GQ was TB4.2 and he converted it to TB4.2 EFI running straight gas. He might be able to help you out
    Todd
