Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Quick Fit Boost Gauge Adapter
    Expert Limmy's Avatar
    hi guys
    saw this on ebay. this bolts on the boost sensor on the intecooler . for zd30 and crd
    would this give accurate reading ? also can i split this to use with dawes valve ? are they worth it ?
    Unafordable
    4 Post(s)
    Yes it should work fine and you can split it to work with Dawes.
    Bought one the other day... sitting on the bench in the shed, to be fitted in the next week or so. Looks to be good quality and I have no reason to believe it wont be anything but awesome. Only issue I can foresee, for the VDO gauge it comes with a small grommet to be installed inside the line, near where the boost pressure is tee'd off. Not sure how Ill go shoving it down the line to be able to get this barbed fitting on the line.
    Teno's Troll...
    08 CRD ST. 2" lift, 33' Maxis Bighorns, Snorkel, ARB Deluxe Bar with Foggies, 12000lbs Avenger Mako TDS with Synthetic rope.
    How did the install go Teno? Do you have any pics? Looking to get one myself shortly.
  5. #5
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    Have one installed. Works great, took all of 1min to install. Undo two bolts and screw up the new two bolts and its done
  6. #6
    Good easy mod Limmy. Get one. They seem to work well with no issues. Easy to fit too.
  7. #7
    yep these are awesome !! perfect fit
  8. #8
    Expert Teamdjbilo's Avatar
    Currently Crabbes Creek NSW
    Works great got one installed and took a whole of maybe 10 mins after taking cover off ect works great and easy install no welding required!
  9. #9
    Install went good. No issues. Can get pics if you want but nothing fancy is required. It might be a little high as I had to bend the engine cover slightly to get it back on. No big deal.
    Teno's Troll...
  10. #10
    177 Post(s)
    G'day all, just resurrecting this thread. One of these arrived with my gauges this morning, was curious as to what it was. So simply put, this eliminates any welding/drilling into intercooler etc, and simply bolts on for the boost probe?
