Results 11 to 20 of 28
Thread: Got my GU, annoying door switch problem
    Adelaide, SA
    LOL, welcome to our world Hodge! Nothing like driving around town with the interior going off like an 80's disco :-). I tried the magnet, worked for a while but started flashing again recently (might even try two magnets). Called the local Nissan dealer - $30+ for a new switch AND $30+ for the rubber boot...Daylight robbery. I'm going ot the wreckers and get one out of a front or rear door for $5 to try.
  2. #12
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Quote Originally Posted by Lowie View Post
    At those prices there won't be too much stock moving off the shelf!!!
    1999 GU 4500 dual fuel
    Il dado è tratto
  3. #13
    Adelaide, SA
    Reckon so, nearly chocked on my wheeties when he gave me the price. Told him I didn't want to buy a full set!
  4. #14
    177 Post(s)
    Fixed mine up last night actually. Realized my switch is just not being pushed in enough, hence the magnet trick someone mentioned. But all I done was take the switch out, take the rubber boot off the switch and I put a bit of plastic (can use anything) at the bottom of the deeper part of the boot where the actually switch piston slides into. This makes the switch being pushed in further than usualy once door shuts and works like a charm.
    And Lowie, I asked nissan about the switch, and gave the guy a good laugh when he told me the price. lol
    177 Post(s)
    Resurrecting this old thread.
    OK this problem is haunting me again. Tested all switches and no bingo.
    Mate of mine reckons there is a hidden switch behind the trim on the large rear door. Could somebody clarify this before I begin pulling the door apart.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Yes there is a switch for the large barn door.
    Where is it located....not sure I would guess on the bottom locking mechanism within the large barn door.
    The interior light coming on randomly is not normally caused be a faulty door switch.
    It's normally an incorrectly adjusted door or a problem with a wire harness shorting to ground.
  7. The Following User Says Thank You to Yendor For This Useful Post:
    Hodge (13th July 2013)
  8. #17
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    Interesting there is a switch in the larger barn door, can't for the life of me think why as you always have to open the small one first, I know there is/was a switch on my small door, although I have a series one GU.
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
  9. #18
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by trekster View Post
    Don't take my word on it, test it for yourself.
    Open both barn doors, interior light will come on........ manually push the switch in the small barn door. What happens to the interior light?
    Close the large barn door and then manually push the switch in the small barn door. What happens to the interior light?
  10. #19
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    The Switch is on the larger door because you can close the small door when the big one isn't closed properly.
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  11. The Following User Says Thank You to Punderhead For This Useful Post:
  12. #20
    177 Post(s)
    So if this switch ends up being faulty I can get rid of it, as it is pretty much useless.
    Edit: My problem at the moment is not a flickering dash light. The door open light on dash stays permanently on, and my interior lights are set to OFF because they don't go off, when all doors are shut, even when locked. So as above, all switches are tested apart from that hidden large one, which I didn't know existed until mate mentioned it this morning to me.
