Results 21 to 30 of 32
Thread: Has anyone used a tiger z winch?
    Expert Blownlc's Avatar
    Werribee Vic
    I have the 12000lb grande on my rig. Haven't used for its purpose yet. However I used it to lower a mini minor shell down my old mans driveway that goes down to to the basement, which is quite steep.
    The winch is very noisy, it started to make a grinding sound and really slowed down. I stopped which for a second and then restarted and it seemed to be fine. I don't think this is normal, should I rip it out and take it back? Any thoughts?
    LESS YAP YAP, MORE TAP TAP!!
    http://www.nissanpatrol.com.au/forums/image.php?type=sigpic&userid=8495&dateline=1347611  053
  2. #22
    Thomastown, Melbourne
    6 Post(s)
    Did you have the engine running and did you increase the revs to cope with the load??????
    Remember it is an electric winch and if you get a voltage drop it is not good for the winch...
  3. #23
    They all seem to do the job ,but has anyone tried getting spares or overhaul kits for them.
    Might just be other products that are Shite like awning.
  4. #24
    Werribee Vic
    The engine was running and I flicked the engine warm up button to lift the revs. What range do you think the revs should be at?
  5. #25
    Expert Forced Offroad's Avatar
    Apr 2011
    Logan/Daisy Hill
    you can get a winch service kit or the Tigerz through super Cheap Auto. Tigerz,Roo,Ridge Ryder and BCF are all selling the the same winch at various Prices...
    http://www.supercheapauto.com.au/onl...d=326361#Cross
    Its not a overhaul kit but if your needs a new service with seals and new solenoid this will get you out of trouble foe $100
    FORCED OFFROAD
    Built by NISSAN Powered by HOLDEN Perfected by ME "hulksta"
    http://www.youtube.com/watch?v=3GX2M...layer_embedded
    http://www.nissanpatrol.com.au/forum...Gq-v8-daul-cab.
  6. The Following 3 Users Say Thank You to Forced Offroad For This Useful Post:
    04OFF (16th May 2013), Bloodyaussie (16th May 2013), threedogs (20th May 2013)
  7. #26
    84 Post(s)
    The Aldi winch I picked up, cheap, had water in the gearbox. After spending quite some time cleaning and regreasing it, I have added an extra O ring to the clutch handle, and have used silicon to make seals for the cable drum. I used an electrical Junction box which seals properly, for the control box. when all of it has dried for a few days, I will put it in a big container of water and run it. Fingers crossed.
    Ran the winch in a 40 litre container and then stripped it down, not a drop made it past the new seals. Feel a lot happier fitting it to the Old Trol now.
  8. The Following User Says Thank You to mudnut For This Useful Post:
    NP99 (16th May 2013)
  9. #27
    6 Post(s)
    Brilliant mate......
  10. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    mudnut (16th May 2013)
  11. #28
    Apparently,the melbourne 4x4 show won't be having the tigerz and Roo systems partake as a few of the bigger players have gotten a bit upset with the newcomer.I am part of another online forum where there is a write up about it.
  12. #29
    Quote Originally Posted by wa 489 View Post
    Hi mate there is a 25 page write up here too and pretty well every 4wd forum on the net also has a big thread about it. "a bit upset with the newcomer" does not even come close to the whole story there mate, Have a bit of a search around the web and you will find sooo much more too it. Mr Roothy calling the rest of us "Un Australian" while he peddles his cheap Chinese copies of Australian made and designed product that he ripped off his previous Advertisers is a little more than people getting upset with a Newcomer. The leeches should stay home. Happy Days
  13. The Following 5 Users Say Thank You to MudRunnerTD For This Useful Post:
    Avo (20th May 2013), Forced Offroad (21st May 2013), taslucas (20th May 2013), threedogs (20th May 2013), Winnie (10th July 2014)
  14. #30
    Takes me half an hour to find what i wrote ealier in the day but will try and find it.Stay calm and have a beer i am new here and will find my way as i go.No i didn't take offence to what you said and i will read the thread if i find it.Sounds like a lot of people don't have a problem with there winches but....
    I will now flip that lid and hop back in my box............................and do some research
    Cheers neil
  15. The Following User Says Thank You to Avo For This Useful Post:
    MudRunnerTD (20th May 2013)
