Are there any other bolts in the OE mounting kit you can check if metric or imperial???
Lucas with the soft and mushy GQ nuts this is the mounting style of this ARB bar
ImageUploadedByTapatalk 21368069000.622150.jpgImageUploadedByTapatalk 21368069022.313049.jpg
The bolt is 40mm long 1/2" UNC13
Going by whats in front of me you have 4 captive nuts and another 4 that need their own nuts.
Get one bolt to try if its all good you will need
8 x spring washers
12 x flat washers ( which need to have an out side diameter of 35mm )
4 x nuts
8 x bolts
To make things a little harder fr you the bolts on the left side will probably be different than the ones on the right. They are on both my GQs.
If you're happy and you know it tap a post!
40mm x 1/2" love it ,do it myself all the time eg need some steel 100mm by four inches LOL
Is it worth while using 1/2 in UNC NYLOCs
Most 1/2" will be UNC
Nah it's a different set up altogether. The bullbar slides inside the chassis rails. It has three captive nuts per side. When the bullbar is slid in, the nuts line up perfect with holes in the chassis rail. The six nuts appear to be the same. I'll get some pics after work.
But thanks heaps for the replies guys. Keep up the good work:-)
FanTapstic!
Hello from Under Down Under!
This slides in the rail aswell
Unless these bars are made in different years and the style has chsnged
Ahh, sorry couldn't tell from the first pics. My bar may have been modified at some stage too. It's damn tough though:-)
FanTapstic!
Hurry up and give my car back George and stop stuffing about with Lucas!!!!!
