Results 1 to 7 of 7
Thread: GU II noise from front end when going into 4WD?
    Apr 2013
    Gold Coast, QLD
    Hi all,
    I test drove a 2000 GU II Auto today. Well kept, no rust, decent condition for it's age, very clean engine bay. Took it for a test drive. 2WD was fine. Thought I probably should test 4WD so stopped, put it in Neutral, engaged 4H, into drive, a fast and loud clack clack noise was coming from the front wheels area, even louder when braking. Tried 4L, same thing. Back into 2H, it's fine. Does this sound like CV joints? I'm not buying the car now but just interested if this is what it sounds like.
    Also as a side note the radiator fan was cracked everywhere around the base between the fins. Is this a simple repair?
    Dan
    477 Post(s)
    Im no expert but it does sound like cv's or the transfer case oil is shot.
    As for the fan. Common problem, no biggie. I take it that it's a 3lr. If so you can use the TB45 fan which is cheaper. By memory there's about 6mm in the offset. Im using one right now on my 3ltr.
    I tapped that app...
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    were you on bitumen when you tried 4wd? Do GUII have auto locking hubs? Did it look like the vehicle had ever been used in 4wd or just a town car that may dried up?
    Hello from Under Down Under!
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    ^^^^ Maybe could have manually locked the hubs and tried it to see if it was the same?
    Apr 2013
    Gold Coast, QLD
    It was a TB45 model but good to know it's no biggie.
    I was on bituman. The GU II does have auto locking hubs (the hubs had an auto and lock setting on the hub. You needed a spanner to change it though).
    It was used for mainly towing it seems as it had a tow bar and no signs of offroad use. Maybe dirt roads as it was a little dirty underneath. I'd say 4WD hadn't been used in a long time (if @ all).
  6. #6
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    Quite possible a hub sticking then, they make a clicking noise when they play up. Apparently they can be cleaned and lubricated to fix this issue.
    GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
    KEEP OUR TRACKS LITTER FREE!
  7. #7
    Jul 2012
    It could be the auto locking hub not properly engaging maybe brought by seldom-used or never been-used engagement. That clack sound usually comes out when disengaging the 4W is not successful which could be stopped by doing the full stop, slow reverse then move to 2W. Try doing that unlocking the 4W then drive shortly in 2W. At low speed, shift to 4W H. If clack sound will still come out, you need to stop and step out and check the auto hub if it deed locked out (an indicator is provided on the hub). If its locked, you got a damaged auto lock hub. But in either case bring a mechanic in.
    If the clack sound disappeared, then it just failed to lock properly at your first try. It happens if 4W driving is not used for long while like 3 years or more.
    The trasfercase would not make a clack sound. It sounds, " Grrrrrr". You can feel that if you hold the 4W shift knob.
