Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 58
Thread: GQ auto problem- ALMOST fixed still need some help/ideas/suggestions to nail it
  1. #21
    Expert soulburner2000's Avatar
    Feb 2013
    Sunshine Coast (Buderim), QLD, AUS
    gonna try the 330 ohm resistor fix before I do anything else
  2. #22
    Beginner pacs's Avatar
    Mar 2011
    hey mate just a query have you tried adding a manual lockup switch for the TC as taslucas and I have experienced issues with flaring with the TC in the past and I added one to force lockup when this occurred and found the flaring would disappear after I manually locked the TC
    there are a few threads around for doing this might be worth checking out as it is an easy job for the DIY
  3. #23
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Hi mate, can you check something for me when you have time
    The Gearbox dipstick does it have "HOT" written on one side and "Cold" written on the other side?
    The Engine Oil dipstick does it have "FULL and "LOW" written on it
    Yes the Engine oil Dipstick has a code/number on it where else the transmission has no code/number on it
    I found your photo's of the dipsticks strange as mine have 2 different types of handle
    This is my gearbox oil dipstick handle
    This is my engine oil dipstick handle
    Toddie
  4. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    taslucas (30th April 2013)
  5. #24
    Feb 2013
    Toddie
    My engine oil dipstick has only the letters - F for full (or H - high? only an hour ago I checked & forgot already) and L for low
  6. #25
    Feb 2013
    Quote Originally Posted by pacs View Post
    have been considering it
  7. #26
    Aug 2010
    17 Post(s)
    Quote Originally Posted by soulburner2000 View Post
    What about the gearbox?
  8. #27
    Feb 2013
    "HOT" written on one side and "Cold" written on the other side - as you describe.
  9. The Following User Says Thank You to soulburner2000 For This Useful Post:
    NissanGQ4.2 (1st May 2013)
  10. #28
    Feb 2013
    Can someone please send me a link for a GQ? Preferably with easy to understand instructions.
    Also, beside cost, what is better about the DIY method? Are the switches you can buy online any different?
    Thanks...
  11. #29
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Hey mate, I can't post a link at the moment as I'm on my phone but if you use the search function on this forum you should find a few threads about these switches including a DIY. There was a very in depth diy done a while ago. Try searching for lockup switch, TC lockup, lockup solenoid bypass etc.....
    FanTapstic!
    Hello from Under Down Under!
  12. The Following User Says Thank You to taslucas For This Useful Post:
    soulburner2000 (2nd May 2013)
  13. #30
    Aug 2010
    17 Post(s)
    Some light reading for you Craig, the only difference I would see between a bought one and a do it yourself is the cost, I don't think there would be any real difference
    Hopefully ripper or chaz will see this and comment
    Todd
    http://www.nissanpatrol.com.au/forum...otts-of-photos)
    http://www.chaz.yellowfoot.org/Locku...s%20Switch.htm
  14. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
