Page 29 of 52 FirstFirst ... 2728293031 ... LastLast
Results 281 to 290 of 518
Thread: Toughest Patrol??? GQ or GU
  1. #281
    Legendary Alitis007's Avatar
    15 Post(s)
    Ok you GQueers, how do you make a GU tougher?? Easy! lift and tyres. How do make a GQ tougher?? Not so easy, you need tyres, suspension lift, body lift, GU diffs, GU steering box and for the diesel boys GU injector pump, GU injectors and turbo set up. Yet from a distance if you put a GQ next to a 60 series they look pretty similar so how TUFF can your Q be if it looks like a cruiser???
  2. #282
    A GQ looks as much like a 60 as a GU does a 100
    I was passenger in a Y62 today when a mate took one for a test drive. POWERRRRRRRR!!!!
    If you're happy and you know it tap a post!
  3. #283
    15 Post(s)
    GQ shoe box!!
    Chris wheres the pics?? Videos????
  4. #284
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by Alitis007 View Post
    I will respect your opinion when it's gets a little closer to the truth!
    Why would you suggest that all GQs need a body lift???
    I wait in anticipation to see your GU's build thread stop at just lift and tyres.
    FanTapstic!
    Hello from Under Down Under!
  5. #285
    22 Post(s)
    1.I dont use a gu pump on on mine it dosnt supply enough fuel.
    2. I dont need a body lift.
    3. Modifying a GQ to make it tough is as easy as a GU to make tough. A set of tyres and a bit of lift isnt tough. To go tough you still need to redo panhards control arms radius arms etc. Or to go harder 4 links, 5 links etc
    4. A GU steering box also came out on the late model GQ's
    5. there are plenty of tough GQ's without GU diffs.
    6. your GU isnt tough.
    96 GQ coil/Cab
    08 G6eT
  6. #286
    Aug 2011
    North West Tas
    56 Post(s)
    Hahaha, nuff said
    FanTapstic!
  7. The Following User Says Thank You to taslucas For This Useful Post:
    Winnie (1st May 2013)
  8. #287
    15 Post(s)
    FanTapstic!
    Technicalities boyz !!
    Lucas i didn't say all i just mentioned some mods that are done to Qs. When i do my build apart from lift and tyres i'll probably make it weaker if anything depending on my choice of motor upgrade, coz when you change anything from standard your changing the way it was initially setup so in theory modifications are the weak points unless your upgrades are genuine OEM from a newer model.
    Bene as you know a lift isn't just springs and shocks and when i said lift those components are included. So your saying that early GQ's aren't as tough as the later Q's coz they have are smaller steering box or other heavier duty components that the U's inherited? You do have a turbo yeh ? Do it would naturally need the boost compensator and possibly other components from a GU pump to help it work efficiently right??
    You make me laugh mate, my GU is tough from factory coz ITS A GU! Just coz its not a bush pig doesn't make it any weaker then any other U!
    ^_^No GQ's where harmed in the making of my GU^_^
  9. #288
    Aug 2011
    North West Tas
    56 Post(s)
    Dude!? That is soooo wrong!!
    FanTapstic!
  10. The Following User Says Thank You to taslucas For This Useful Post:
    Ben-e-boy (1st May 2013)
  11. #289
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Maybe we should have another thread for "more capable". Which both series can be with some modifications. As stock on the outisde I probably see it as a GQ being tougher as there is thicker metal and paint around it ...so easy to damage the U's...like tin foil with a spray of crap
    ________________________
    ______ 2017 D-Max _______
  12. #290
    22 Post(s)
    Lucas i didn't say all i just mentioned some mods that are done to Qs. When i do my build apart from lift and tyres i'll probably make it weaker if anything depending on my choice of motor upgrade, what kind of power are we looking at? what suspension mods that may not be up to the task?
    in theory communism works too
    the aftermarket suspension components from quality manufacturers (superior engineering for example) have proven themselves better than nissan except bushes which no one has managed to improve on. give me 1 example of aftermarke suspension parts that are weaker than standard.
    Bene as you know a lift isn't just springs and shocks and when i said lift those components are included. So how is it easier to do the same thing?
    So your saying that early GQ's aren't as tough as the later Q's coz they have are smaller steering box or other heavier duty components that the U's inherited? they are both hefty units no matter which way you look at it.
    my pump contains aftermarket parts nothing was sourced from a gu
    true though its purpose in life has a softer approach.
    Go to a wrecker look at the amount go wrecked GQ's to the amount of GU's. Plenty of GU's were harmed to make a tough GQ
    96 GQ coil/Cab
    08 G6eT
