Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: egr block
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by kevin07 View Post
    from what ive read the majority are adjusting turbo so if it happens to me ill probably look at that or chase up some parts and do the double dawes as i like the boost curve on the diagrams put up by chaz hope im right by saying chaz i do have the diagrams saved for this setup
    Yeah I know about adjusting the VNT actuator screw but I wanted to leave all that untouched and just install the dawes valve to control that boost spike.....
    I do like Chazs double dawes setup tho...http://www.chaz.yellowfoot.org/Manua...Controller.htm
    I want to keep the modifications to minimum so I might even take the block out all together...
    ________________________
    ______ 2017 D-Max _______
  2. #12
    476 Post(s)
    Don't waste your time with the double dawes setup. Theres not much difference between 10 and 15psi, or there abouts. I did it but found I just kept it on the higher boost setting so I ripped it out. The was no difference in fuel eco between the two settings and power difference I could notice it, albeit small, so it stayed on the higher setting.
    Your best off installing a needle valve along with the dawes to control the spool up rate of the turbo, getting a better zorst and chip.
    Mark.
    Edit : keep the block in nisshead. Your doing your engine good with it in.
  3. The Following User Says Thank You to mudski For This Useful Post:
    kevin07 (10th April 2013)
  4. #13
    Patrol Freak kevin07's Avatar
    georges hall
    Good to hear mate. I did mine a while ago and the car feels great around town but went for quick spin to Vic and back on the weekend and noticed I was boosting to 22psi when cruising at 110k's. It was only doing it at cruising speeds between 100 and 120 and if I accelerated or deccelerated the boost would drop down ...hmmmmm ???
    I'm just resetting the computer to see how it goes but I have ordered a dawes valve just in case.
    Have you tried yours on the highway cruising at constant 110k's??? be interested to see the result as you have same motor and exhaust
    ok took it for a spin on m5 on my way home from work went through speeds of 100 to 120 so at 110kph just cruisin along boost was 11psi steady egts were 320c im pretty happy with that.kev
    13 y62 the beast that burbles
  5. The Following User Says Thank You to kevin07 For This Useful Post:
    Maxhead (18th April 2013)
  6. #14
    Beginner 4MUD's Avatar
    Sep 2011
    Hunter Valley
    hi guys, I fitted the dawes valve to my 08 crd and fixed all overboosting issues, will need to readjusted after a few 1000kms as it losses its initial setting due to general wear and tear. set mine to 16psi and pulls nice and hard. when shifting hard it only spikes to 19psi for a very minut second so thats spot on.
    Just wondering which end you blanked the egr wether it was on the exhast or inlet end. photos would be great. Also did you make the plate or buy it online.
    How's the serenity boots's Avatar
    Sep 2011
    Inlet side for the egr block is the easiest and online to purchase . A couple of the members sell them here - the ferrett , and mudski from memory .
    The price of excellence is dicipline , the cost of mediocrity is dissapointment .
  8. #16
    georges hall
    Quote Originally Posted by 4MUD View Post
    blocked it at inlet bought from bertye on ebay
  9. #17
    Patrol Guru SonOf's Avatar
    Dover, Tasmania
    I did the EGR block and added the dawes valve - was getting excellent fuel economy & the boost was far more linear, sitting on about 10psi at 100kmh. It is pretty easy to fit the dawes and would highly recommend it
  10. The Following User Says Thank You to SonOf For This Useful Post:
    Maxhead (19th April 2013)
  11. #18
    Apr 2013
    West of Melb
    I fitted a Dawes Valve and boast gauge on a pillar pod. Set the Valve to 18psi, no problems.
    i blocked the egr on sunday morning well thats made a difference more power and a lot smoother. boost i can only make it boost to 17 maybe once to 18 as this spike otherwise it behaves very good i can see the boost comes on quicker, and the egts are lower have not really checked properly yet but probably about a hundred odd and ill see when i take it for a run.kev
