Results 1 to 10 of 18
Thread: egr block
    Patrol Freak kevin07's Avatar
    georges hall
    egr block
    i blocked the egr on sunday morning well thats made a difference more power and a lot smoother. boost i can only make it boost to 17 maybe once to 18 as this spike otherwise it behaves very good i can see the boost comes on quicker, and the egts are lower have not really checked properly yet but probably about a hundred odd and ill see when i take it for a run.kev
    13 y62 the beast that burbles
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by kevin07 View Post
    Good to hear mate. I did mine a while ago and the car feels great around town but went for quick spin to Vic and back on the weekend and noticed I was boosting to 22psi when cruising at 110k's. It was only doing it at cruising speeds between 100 and 120 and if I accelerated or deccelerated the boost would drop down ...hmmmmm ???
    I'm just resetting the computer to see how it goes but I have ordered a dawes valve just in case.
    Have you tried yours on the highway cruising at constant 110k's??? be interested to see the result as you have same motor and exhaust
    ________________________
    ______ 2017 D-Max _______
  3. The Following User Says Thank You to Maxhead For This Useful Post:
    kevin07 (10th April 2013)
    georges hall
    ill give it a run on the weekend see how it goes tell me how did yours behave when you fitted the zorst
    Was there a post a while back about the CR needing a hole in the EGR plate to stop throwing up errors.
    Not that long ago
  6. The Following User Says Thank You to threedogs For This Useful Post:
    ACT
    Yeah, it was a different vehicle after fitting the exhaust...soooo much more grunt and torque but no over boost issues till EGR block...
  8. The Following User Says Thank You to Maxhead For This Useful Post:
  9. #6
    ACT
    Not that long ago
    No one here is talking about EGR errors. I was saying mine overboosts when cruising at 110ks
  10. The Following User Says Thank You to Maxhead For This Useful Post:
  11. #7
    georges hall
    i have read a bit about them and they only throw a code every so often i have the ultraguage handy
  12. #8
    Perth WA, NOR
    I think it's something to do with the egr valve opening and closing at cruising speed/lower engine loads.
    Not sure if this is correct:
    1. At idle Egr opens to let crap exhaust recirculate
    2. You accellerate off and egr closes and boost comes on (high egts)
    3. You hit cruising speed. Ecu reads there's low (less than ~55%?? on scangauge) engine load and cruising. Ecu opens the egr valve (even though it's blocked)
    4. Bosst pressure increases as more air is flowing??? egt lower
    5. Accellerate (more load) egr closes, less boost, more fuel = higher egts
    Sooo this happens even on a stock CRD. Try it...
    Get up to 100 and cruise. When you are going slightly (less load) down hill you'll notice boost increases.(egr opening) EGTS go way down as more air is flowing
    Tap the accellerartor and egr closes and boost goes lower and egt rise as more fuel is being pumped with less air.
    Bigger exhaust just makes the boost value slightly higher
    Then the EGR block raises the boost even more.
    Just what i think what happens. Might be wrong.
    Patrol GU8, Manual, snorkel, steel bull bar, Simpson Ed
  13. The Following 2 Users Say Thank You to schanmala For This Useful Post:
    kevin07 (10th April 2013), Maxhead (10th April 2013)
  14. #9
    ACT
    Quote Originally Posted by schanmala View Post
    Mate you are absolutely spot on from my observations. I experimented this on the highway and come to the same conclusion as above.
    I had the battery disconnected overnight and just went for a drive and still have the 22psi at cruise speed. It seems to occur more around the 100-120ks(haven't been any quicker since block) but it could be happening at lower cruising speeds without such big boost increase.
    So....now I am waiting for my dawes valve to arrive so I can control the boost and limit it to 15/16 psi.
  15. The Following User Says Thank You to Maxhead For This Useful Post:
  16. #10
    georges hall
    from what ive read the majority are adjusting turbo so if it happens to me ill probably look at that or chase up some parts and do the double dawes as i like the boost curve on the diagrams put up by chaz hope im right by saying chaz i do have the diagrams saved for this setup
