Results 1 to 10 of 16
Thread: Out with the Old, In with the New
    Advanced modustollens's Avatar
    So, my old engine decided it would no longer start. It would quickly overheat even at -20! I though - maybe thermostat, maybe water pump? I took out the thermostat but it opened in hot water. Never did get the engine started again after that.
    So, rather than cry all the time I decided to cry once and get a replacement engine. My old was bad - I burned more oil than fuel and sometimes when i was driving on the highway it would make strange clunking sounds, loose all power and spew out grey and brown smoke. There was oil in the anti-freeze and if one tried to crank the engine with the radiator cap off exhaust gases would come out.
    I went by the mechanic yesterday and took some pics of the old engine and one of the new. Here is what I saw:
    This is the engine that will be installed:
    This is the top of the old engine with the turbo lying on the ground:
    Looking down at the pistons on the lower half of the engine still in the truck - it gets pulled out today:
    I scrapped some of the crud off the top of one of the pistons:
    Do these pistons look normal?
    Soon I will be driving again!
    MT
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Pistons look ok to me but the ridges in the bores/cylinders look bad might be me looking from my phone is all. You will tell when/if you take the pistons out there should be 3 or 4 rings around the pistons they might be broken or missing
    Just tap it in just tappy tappy tappy
    Dec 2012
    Bunbury
    And see the residue(stuff) between number 2 and 3 cylinders might have also been your problem
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    Congrats with new engine! Show us pics of first start and ride.
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
    The new ride may be delayed. Just got a report from the mechanic. Apparently it is the same engine but there is a problem with the fit. Not sure exactly what the issue is though - engine mounts, transmission coupling - who knows. All I know is that my bumpy rides in the mud will be delayed even longer.
    MT
  6. #6
    Was the original a diesel?
    Owner of
    Westy's Accessories
    Yes - original is diesel; new one too - supposed to be the same engine; 2.8tdl was written on the valve cover too. Not sure what the problem could be now. It will get sorted soon with either time or money.
    MT
  8. The Following User Says Thank You to modustollens For This Useful Post:
    BigRAWesty (9th April 2013)
  9. #8
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    Did you check turbo shaft free play?
  10. #9
    No - I have not done any of this work - the mechanic and my girlfriend`s father are working this out given that I can speak to any of the locals. So, I am not sure what she meant when she said it `doesn`t fit.` Indeed, even she does not understand how to translate car speak into English. So, I must wait and see what happens!
    MT
  11. #10
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    May be engine donor was non turbo Laurel or Cedric. So they can have differences in fixing point and fuel pumps.
