Results 1 to 4 of 4
Thread: EGT probe installation
    Mar 2013
    Any tips on installing an EGT probe before I launch into it? Any gotchas removing / installing the exhaust pipe? Drill and tap the pipe for the probe or drill and weld on a nut? Cheers.
    How's the serenity boots's Avatar
    Sep 2011
    Drill and weld on a nut Hesso . 50mm away from turbo outlet / flange is the ideal .
    Expert WYLD333's Avatar
    Nov 2012
    Pakenham
    Welding a nut on is the best option, when I installed mine I needed it done quick so I just drilled and taped mine and it has been sweet doesn't even look like it will ever wrk loose
  4. The Following User Says Thank You to WYLD333 For This Useful Post:
    Stropp (1st April 2013)
    Patrol God Stropp's Avatar
    38 Post(s)
    Same as mine wyld333, my dump pipe is cast not steel so reasonably thick.
