Results 1 to 10 of 16
Thread: Suspension lower on one side?
    Expert billy bleed's Avatar
    Mar 2013
    I got ironman foam suspension kit that's 6 months old roughly - noticed the other day that the rear left sits about an inch or so lower than the right.. Anything I should be concerned about?
    Black Irish with an English twist / Gypsy / Tattoo's and loaded full of Grumpiness.. I blog my paintings and other random bits on Billy Bleed
    Mar 2013
    btw I'm getting a service in two weeks.. Is it an easy fix or something that will cost $$?
    are these adjustable etc?
    How's the serenity boots's Avatar
    Sep 2011
    Its an easy fix with coil spacers .
    The price of excellence is dicipline , the cost of mediocrity is dissapointment .
    Expert WYLD333's Avatar
    Nov 2012
    Pakenham
    coil spacers are a cheap fix to a problem that will still be there and wouldnt fit them to any car. Has your car always been like this or is it something that has just happened?
    Mar 2013
    I don't know as I purchased the car about 3 months ago.. I have only just noticed it when up at my dads place..
    The suspension and springs were fitted before I purchased the car..
  6. #6
    Nov 2012
    Pakenham
    U may have to have a look at the springs and make sure they have been fitted on the correct sides, u have L/H and R/H sides and if fitted ass about will make your car lean as one side is shorter than the other.
    Hope its just a simple fitment error or you may have to throw some new spring in it mate
  7. The Following User Says Thank You to WYLD333 For This Useful Post:
    Stropp (30th March 2013)
  8. #7
    Expert nickpeacock36's Avatar
    Oct 2010
    North Lakes Qld
    Re: Suspension lower on one side?
    Had to put a spacer in my GU with iron man springs. It does the trick but i guess they aernt the best quality out there.
    Sent from my GT-S7500T using Tapatalk 2
  9. #8
    Mar 2013
    Ill point it out to the mechanics and see what they suggest..
    If I kept the iron man shocks would it be worthwhile updating the springs with a better quality brand?
    Or is this something I should be doing as a complete refit?
    How much (ball park) does it cost to replace with a new system with a decent product?
  10. #9
    You have left and right hand springs to compensate for weight of the driver. easy enough fix if thats the problem
  11. #10
    Mar 2013
    I'm thinking the PO did the lift himself.. Hopefully it's a simple fix so I can spend my cash on more fun stuff..
