Results 21 to 30 of 39
Thread: Using an Eonon Head unit GPS in a Nissan Patrol
    Quote Originally Posted by oncedisturbed View Post
    Justin, I have installed a few of the G2216 units in various cars including the wifes epica without an issue.
    I did a trial fit in my 09 patrol without any dramas at all, needed to purchase an Aerpro plug and play ISO harness and aerial adapter and worked fine. The DVD in the unit works fine BUT the gps unit needs a lot of work, constantly loses signal but when it does gain signal it works great.
    I am in the process of looking for another unit as my current JVC unit's bluetooth is in the blink.
    You can have the DVD screen in view of the driver BUT it is not allow to display any movie / tv etc by law unless vehicle is stopped / turned off and handbrake applied hence rooftop / headrest screens. The earth wire for the dvd section is supposed to be earthed to the handbrake and not earthed anywhere else ie chasis etc.
    If you are looking doing 1 for the patrol, I would honestly suggest looking at incorporating an offroad gps mapset like Ozi Explorer CE or similar for them like many other providers are doing with the WinCE 6.0 operating systems.
    Can always throw a unit my way and happy test out lol.
    Good to see another company here to support us Patrollians
    Tap, Tap, Taparoo
    Also forgot to mention that Eonon may need to look at either incorporating an anti glare shield or utilising and anti glare film / filter for the units as soon as the sun comes through 9 out of 10 times you can not see the screen to answer calls, change stations, access gps etc.
    Just food for thought
    Tap, Tap, Taparoo
    Hi oncedisturbed, thanks for sharing your Eonon experience, and glad to hear you enjoy them!
    About the wiring, so you mean if you install a standard 2 din unit like our previous G2216, and Aerpro plug is needed? Is it the same as the one in this pic?
    If so, it seems quite familiar with the D5168 harness (No. 4 in the pic):
    Could you please check for us? Many thanks!
    And thanks for your advice regarding the gps and anti glare film, I’ll reflect them to our R&D then. About the Win 6.0 system, our D5168 is already used this OS, welcome to get it in the future!
    I have a G2227 in my 2001 GUII. Fitted no problem. Only issue I have is the gps can take up to 30minutes to actually work. By that time I have found my own way...
    O.h the other issue which is quite annoying is the radio reception. Very poor. I hope the newer units are better...
    Hi mudski, thanks for your info too.
    About the radio reception issue, you can check as follows:
    1. Make sure the radio antenna is well connected, unplug it several times to have a try.
    2. Choose the right radio region.
    3. Turn off the LOC function.
    4. Change to another FM antenna to have a try.
    Hope it helps, please have a try!
  2. #22
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Justin, the harness looks pretty close from memory to the Aerpro harness I used. The antenna port is completely different though as I had to use again an Aerpro converter plug to convert from a Nissan 2 pin to a standard universal fitting in order to plug in the antenna
    Never underestimate the power of the Tap.
    www.swat4x4.com
  3. The Following 2 Users Say Thank You to oncedisturbed For This Useful Post:
    Justin220 (22nd March 2013), MudRunnerTD (22nd March 2013)
  4. #23
    Hi oncedisturbed, I'm Carlos, lol:
    Thanks for your feedback, really valuable! I've asked our tech to compare the Aerpro harness and D5168 harness, he said from the look of the white end, the size are quite similar between them. Cheers!
  5. #24
    476 Post(s)
    Lol, I forgot to mention too. To get better radio reception I have to touch the screen or plastic frame of the unit whilst I'm driving. Not bad if I'm in 5th gear but rather annoying. I think I will be pulling it out soon and seeing if I can make it any better myself.
  6. #25
    Legendary Alitis007's Avatar
    15 Post(s)
    Does your rig have the areal in the rear window??
    Alot of the after market areal adaptors that go from the nissan 2 pin plug only use 1 pin. I got and after market adaptor that had used both pins but had 2 wires and i spliced them to 1, not hard just fiddly and my radio reception is pretty good and only get crackle when i turn my HID head lights on which is standard coz of the frequency the ballast emits!
  7. #26
    15 Post(s)
    This is the best pic i have, had to zoom in on it from another pic
    I got that adaptor from autobahn
  8. #27
    476 Post(s)
    Didn't know the trolls had a rear window aerial. I just have the one on the front quarter. I dont want to add more aerials too. It should work in the first place.
  9. #28
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Yeah I think they have 2, one at the front and one on the back window. The aerial plug is a 2 pin plug.
    The GU8 hasn't got one at the front anymore as it was a bad spot and they keep breaking
    ________________________
    ______ 2017 D-Max _______
  10. #29
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    I thought is was a demister
    http://www.nissanpatrol.com.au/forum...-Side-Demister
    “The best way to cheer yourself is to cheer somebody else up.” - Albert Einstein
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
  11. #30
    15 Post(s)
    There is an amplified retractable one on the front guard and one on the passenger side window in the cargo area on my rig but its late '99
