That is bloody brilliant Alex, great job mate, you should be proud of your efforts and idea mate, Absolutely love it. Good work,
TAPPN OUT
TAPPN OUT
"Tonka Tuff" 08-GU6, 3.0lt crd, 5 Speed, Turbo Diesel, Hpd, Arb, Ome, MT Baja Atz.![]()
altech (2nd April 2013)
Thats awesome
altech (6th May 2013)
No ,not at all as you can by the video that I made up a spacer made from 3mm scarp wood and left over carpet and glued it on both sides , so it fits frame and perpex no rattle . and the perpex only go's up when needed . eg camping .. regards Alex
http://www.youtube.com/watch?v=TceKoWcsjY4
trekster (12th May 2013)
Mate the steel you found is called unistrut, it's the mechano set og building material. The railing supports hundreds of different types of clips for everything, I love the stuff.
Have look in this direction ,
https://www.google.com.au/search?q=unistrut&client=firefox-a&hs=bVv&rls=org.mozilla:en-USfficial&source=lnms&tbm=isch&sa=X&ei=qqC8UYDjDIbRk gX2yoG4CQ&ved=0CAkQ_AUoAQ&biw=1920&bih=976
altech (18th June 2013)
Cheers Mate that's the stuff and the steel was free , left over from work site.......... lol
altech (26th July 2013)
Thats a tops idea mate
