Results 1 to 5 of 5
Thread: shock absorbers
    Patrol Freak kevin07's Avatar
    georges hall
    shock absorbers
    as i have just put a winch and steel bar on i want to put a set of bit heavier shocks on the front im looking at some rancho rs 5000
    13 y62 the beast that burbles
    Re: shock absorbers
    Quote Originally Posted by kevin07 View Post
    Why's shocks? They don't take any weight, just slow the rebound to take any voice out.
    If your worried about weight you need heavier springs..
    Owner of
    Westy's Accessories
    georges hall
    i know what your saying about the springs just looking for something short term for about a year then ill put 2 inches through all but theres a problem with that sort of coin for the moment
    Re: shock absorbers
    Then don't worry about them if its sagging little then stick in some coil spacers in the short term.
    Finish the mods then get specialized advice on what rate springs and style of shocks to invest in.
    Owner of
    Westy's Accessories
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    kevin07 (12th March 2013)
    Expert grimace's Avatar
    Apr 2011
    central coast N.S.W
    springs will cost around the same amount as the shocks anyway, also take a look on ebay you can pick up second hand gear for next to nothing. i have a set of front spring spacers 30mm brand new TOUGH DOG brand that i bought as a full set (4 of) already fitted the rear but decided not to use them on the front, they cost me $160 will sell the front for $50 if you interested.
    fitting is easy *raise the front of the truck and support on stands then remove the front wheels.
    *slide a hydraulic jack under the truck and support the weight of the diff housing at the mushroom.
    *undo the bottom nut off the shock on both sides and also the top nut off the sway bar links both sides
    *then there is 2 bolts on top of the spring tower which is fixing a cover remove these and under that is another nut which holds the bump stop, remove this both sides
    *now it is a matter of lowering the diff slowly until the springs can be removed being careful not to stretch the brake line too much.
    if you are going to fit spring spacers be sure to cable tie them on top of the spring for hassle free fitting and this method can also be used to fit 2" springs but any higher and you will need spring compressors. this method works well and should not take more than a couple of hours at the very most......cheers......
    * now is just a matter of
    2008 GU 2" LIFT, GME UHF BLACK KING WHEELS, SAFARI SNORKEL, LIGHTFORCE 240' KAYMAR DUAL WHEEL CARRIER STEINBAUER POWER, beaudesert 2 3/4 system, runva 11,000 comp winch.....
  7. The Following User Says Thank You to grimace For This Useful Post:
    BigRAWesty (13th March 2013)
