Results 1 to 10 of 10
Thread: Mounting a radio on top of my dash
    Expert GQPorkroll's Avatar
    Hunter Valley NSW
    I have been looking for a binnacle type box so I can mount my DVD screen radio/nav system on top of my dash.
    My plan is to blank off the original double din sized hole in the center and use it as my switch panel as I'm using ARB type switches and they're too big to fit into the factory holes.
    As I have several switches to fit, and several pilot lights (spot/spread/LED/roof/rear/awning/locker) I'd rather use that panel there and space them neatly.
    Also, as it's a 7" fold out stupid thing, I think if I used the top slot, it would foul on my heater controls or the dash and it would look a bit stupid. Also, my dash is pretty knackered from being abused by previous owner fitting several different stereos and switches and breaking most tabs etc.
    My main problem is it seems that the department of the interior is the only people who make this unit and it's bloody dear. They then want a further $20 or something to cut a din sized hole in it. Now, I'm sure the job they do is outstanding, but at around $500 plus freight, it seems too excessive.
    I'm useless with wood, so I can't make one myself. I have a dash mat fitted and can have it covered in the same material as the dash mat to make it all look stock, so not worried about glassing/painting etc.
    Essentially I need a wooden box made. Surely someone on the forum has done it, or can do it for a much better price than DoTI? I'm not in a massive hurry, but plan on doing my stereo in the next 3 months or so.
    Any ideas?
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Could you use something like this ....
    http://www.autotoys.com/x/product.php?productid=1022
    You could make some tapered sides so it does not appear so "box" like , then cover with dash mat/carpet ?
  3. The Following 2 Users Say Thank You to 04OFF For This Useful Post:
    Bloodyaussie (9th March 2013), GQPorkroll (9th March 2013)
    M2cW make a cardboard template of what you want, either take to cabinet makers to knock one up
    or 2 go to a sheetmetal place, cover with thin foam an vynyl using contact cement
    Re: Mounting a radio on top of my dash
    What about roof console?
    Owner of
    Westy's Accessories
    And velcro to dash save drilling more holes
    84 Post(s)
    If he used a box, would heat be an issue for the electronics on the dash?
  8. #7
    Hunter Valley NSW
    Yeah, that looks perfect, 04. Just got to hope the freight to Aus isn't ridiculous now, or that I can find one in Aus.
    Westy, I have a roof console that houses my cb. Plus it would be a PITA to keep looking up to check nav or if I use a DVD etc.
    Not sure bout heat being an issue, my radio is seldom on, tbh. My CB's are active more than the radio and if there's enough airflow around it, I don't see it being an issue, but I may mount a 2" computer fan in either side, just for peace of mind.
  9. #8
    Brisbane,QLD
    12 Post(s)
    A few types on egay as well...
    http://www.ebay.com/sch/sis.html?_kw...LLATION+SYSTEM
    Doubt you will have many issues with heat, but you could always look at where the heatsinks are on the head unit (normally at the rear), and put some extra holes in the plastic housing in that area, then cover with carpet, or speaker cloth etc.
  10. #9
    Sep 2011
    adelaide
    18 Post(s)
    I have a unit mounted on top of my dash, it`s been there for bout 5 years and have had no issues
    Sorry can`t post any photos as I`m in Melbourne untill after the Grand Prix and the cars in Adelaide
    Car lives in the sun and as said no heat issues Just has alloy cover with carpet glued to it
  11. #10
    Hunter Valley NSW
    Hmm, that's an idea, but I suppose by the time I make a template, buy the mdf, glue and carpet or vinyl, it's probably gonna cost me a few bucks at a cabinet makers anyway.
    I think ill buy the egay single din unit, bit of foam under it, spray it with vinyl spray to match my cluster surround and be done with it for $20.
