Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 109
Thread: HID Projector headlamp kits to suit GQ and GUs
  1. #91
    Expert mick.'s Avatar
    Newcastle (NSW)
    Here's the first of the duel angel eyes in the 7 inch round headlight. The parker is behind the grille in the shroud and the outer leds are indicators. I'll get pics of the leds later. These will also have breathers going into the cabin so they can be fully submerged unlike any other light. These are going in a comp truck I'm sponsering for Tuff truck.
    This is the new D40 light which is one of the more complex conversions. I'll only use genuine Lexus RX 350 Bi-Xenon projectors in these and no angel eyes. The reason being is these lights are worth about $600 each and the lens needs to be actually cut off and then glued back on. Once these lights are put back together they cannot be pulled apart again. So I only use the best projectors available and keep the chinese bits such as angel eyes and devils eyes out of these.
    These are the best projector available world wide and there like stepping up from halogen to projector all over again. The down side is there dearer but well worth it. I now have all the gear to fit these or any other OEM projector in pretty much any headlight without the car.
    Thats only a 35 watt chinese bulb and as you can see it puts out a lot more light then any of the other projectors. Disreguard the reflection but that spraybooth has a heap of freshly painted white panels hanging in there.
  2. #92
    Newcastle (NSW)
    Cool OEM variable wattage incab adjustable ballasts.
    Well how often have you wanted to have a set of headlights that you can change the wattage to suit your driving conditions??
    Well one of my suppliers can now make OEM ballasts (Bosch) that can have the wattage changed on the fly so if your on the road you can have 35 watts or 55 watts or even 70 watts in the bush by the flick of a toggle switch. There are even options of 5 variations but I don't think this is really needed but its available too. These will come potted (waterproof) and heat sink. There is also the options of having boosted OEM ballasts without the need of the variable wattage with these as well.
    I can also get 100w Denso which are fully potted with aluminum enclosures and waterproof ATV fans. These come fully potted and can be bolted outside unlike other guys who are converting these ballasts which aren't waterproof. These are true 100 watt HID Ballasts not 80 watt ballasts marketed as 100 watt like that cheap crap on ebay.lol
    Both these ballasts are OEM meaning they warm up in a couple of seconds and they can also be used on your spotlights too. So these give you the option of super fast OEM warm up times and also variable wattage which is 2 options you cant get with any ebay ballasts.
    Pricing will vary a little depending on the Aussie dollar and the amount of interest I get in these options. I'll also need deposits prior to ordering as there all custom made to customer specs.
    The Bosch variable wattage ballasts will be about $450 delivered or a little cheaper if there included in a projector kit.
    The 100 watt Denso ballasts will be about $450 delivered also but remember even though these are slightly dearer then other companies in the States selling them there are fully waterproof with a waterproof external fan. The other companies don't make these waterproof (don't warrent water damage) and cant be mounted on a roof rack like these can.
  3. The Following User Says Thank You to mick. For This Useful Post:
    Robo (2nd March 2013)
  4. #93
    476 Post(s)
    Few questions for ya Mick. I have a 2001 GUII with the original shitty lights in them...
    1. Which light assemblies should one buy to fit your kits? Theres too many on Ebay to mention.
    2. Could I buy something like this, http://www.ebay.com.au/itm/NISSAN-PA...item43a8290adf
    3. I can have the angle eye in white, PLUS the orange thingo' that comes on with the indicators?
    4. Doesn't blacking out the reflector hamper the performance of the light? There reflector is there for a reason I would have though.
    5. Plus having any colour other than white or amber is illegal too. I wouldn't want to put blue devils eyes in, although it would look awesome, only to be pulled up by the coppers and told to remove them or worse get a fine. Been there, done that one before. With blue lights on my grill...
    6. Can you supply the lot, lights etc etc all fitted up ready to go?
    Sorry for the long drawn out questions.
    Mark.
  5. #94
    Newcastle (NSW)
    Mark.
    Hi Mark
    The lights you have in the link above are the correct lights but you need the option with the indicators as well.
    Yes you can have parker and indicator angel eyes. I'm just letting you know up front angel eyes and devils eyes aren't warranted once the fitted. At the end of the day there only Chinese and no one makes a high quality led. The companies are happy to warrent the LEDs but none will warrent the extra few hundred dollars it costs me to ship the light back, replace the shrouds and do the labour. If an led drops out it's an expensive job for me to fix which is why I don't really recommend them or warrant them. They also attract unwanted attention. I'm happy to fit them though if you want them.
    The reflectors are there for the halogen lights they are not used at all once the projector goes in. If you didn't have to bolt a projector to it you could throw them in the bin. lol
    Yes I can do the retrofit all fitted and ready to go. I would need to know what options you would like and then I can price it accordingly.
    There are 2 main options of projectors one being the bolt in one (Q5) which is $350 for the kit. These are good projectors but if you want something a little better quality and slightly wider beam the Stanley projectors are $400 and a little more to install.
    Cheers Mick.
  6. #95
    476 Post(s)
    Thanks mick. Once the locker is in this will be my next mod. I was thinking of a Light bar but would never use it. This light kit seem to be a better way...
    I'd wanna go the angel eyes with the orange do-dad for the indicators and black out the reflector. If i were to buy the lights and get them sent direct to you. You could do it for me? Or if you can get them up your way and just do it and then send them...What evers easiest I suppose. I know I could do it, but you would do a better job of it plus I haven't got the time to spend doing it all. I'd rather just remove and refit.
  7. #96
    Legendary Alitis007's Avatar
    15 Post(s)
    Do those later style clear lensed head lights fit into the early style cars like this and would you know if they have glass lenses like the earlier style ??
  8. #97
    Newcastle (NSW)
    Hi mate.
    Yes that's perfectly fine. A lot of my customers buy the lights and send them directly to me.
    There are 2 options with the projectors. I'll list both options and prices.
    Just so your aware though that the indicators cant be seperated and the guys that have them painted black actually have the outside painted black not the inside. They look good in pics but I'm not sure what they look like up close as I've never touched the indicators and wont as I don't think they would look to good in 12 months.
    The Q5 kit is $400 with the 50 watt ballasts and angel eyes.
    With the Q5 H4 projectors which are bolt in. To fit these, blacken out the housings and shrouds your looking at $270.
    The other kit is the Stanley projector kit. These are $450 with the 50 watt ballasts and angel eyes. These are better quality projectors which require cutting of the lights so theres a little more labour in fitting and materials.
    To fit these your looking at $400 with black work included.
    Cheers Mick.
  9. #98
    Newcastle (NSW)
    Quote Originally Posted by Alitis007 View Post
    Do those later style clear lensed head lights fit into the early style cars like this?
    Yes mate The series 3 headlights and indicators are a full bolt in replacement. Yes the series 3 lenses are glass also which is lots better then the newer plastic versions.
    Cheers Mick.
  10. The Following User Says Thank You to mick. For This Useful Post:
    Alitis007 (3rd March 2013)
  11. #99
    15 Post(s)
    Do you know if its possible to use series 1 indicator/ parker assemblies with the series 3 head light ???
  12. #100
    Newcastle (NSW)
    No mate there is a massive difference. That's why they sell them as sets on ebay. There about $330 delivered for 2 lights and 2 indicators.
    Cheers Mick.
  13. The Following User Says Thank You to mick. For This Useful Post:
