Results 11 to 20 of 26
Thread: Air Diff Locker On GU
    Advanced knakkers's Avatar
    Hampton Park
    Thanks for the input guys.
    Decision has been made.
    Ive totally switched from my original thorts.
    Patrol is booked in for next Tuesday to get fitted with front Eaton's Elocker.
    Everything 4WD in Cranbourne is doing the job for me.
    I cant wait
    Now Divorced I can do what i like when i like. How good is life now
    02 GU111 Patrol 3.0TD Man, Chipped, Redback 2.5" Exhaust, Safari Snorkel, OME 2'' Lift, ARB W/Bar, Tigerz11 12000Lb Winch & R/Rack, IPF Lights, Cooper S/T Maxx 33's, Dual battery system, Uniden UHF, ARB fridge/freezer on ARB Slider, & heaps more
  2. #12
    177 Post(s)
    Quote Originally Posted by knakkers View Post
    I cant wait
    Please feedback how you find the experience once you've had it done, & more importantly how you find the elocker.
  3. #13
    Expert Steve4wdin's Avatar
    Feb 2012
    Western Sydney
    X2 Very interested in the locka
  4. #14
    Hampton Park
    Will do Cuppa.
    Im going out this Sunday to tracks ive never been to before, out towards Labatouche & Poweltown, see how i travel. I will try to get out again within the next couple of weeks & do the same tracks again & see what a difference it makes.
    Pretty excited at this end fella. Been waiting a long time to get locker fitted
  5. #15
    Legendary happygu's Avatar
    Great stuff - let us know how it goes
  6. #16
    Oct 2011
    Essendon
    Really looking forward to hearing how it goes......
    How much is it setting you back?
    Tip tip tip......tap tap tap....
  7. #17
    Hampton Park
    Not much change out of 2K, which is better then ARB quoted me with onboard compressor fitted as well with air locker
    Quote Originally Posted by Drewboyaus View Post
  8. #18
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    So like 10 months later is there an update or did I miss something somewhere?
  9. #19
    No update. The OP hasn't been here since July...
  10. #20
    Patrol Guru
    NT
    Ok, well I will post up my experience with the elocker. $2200 fitted. Comes with an awesome cube shaped space case.
    Actuation is silent. The way I think they are best used is 1) planned use, activated before an obstacle or 2) didn't think it would be needed, but I'm stuck, and need to get out (maybe last ditch before you break out the shovel!).
    My main experience is mud so far... It doesn't make you suddenly un-stuckable. The same rules apply in mud, momentum being desirable. The difference is that in between the really slippery bits, both front wheels (I had the front only done) are keeping momentum going. Before the vehicle would sometimes come to a halt with one front wheel spinning
    Activating it, once you had come to a halt in mud, still leaves a dicey feeling when you get going again.
    In sand, (haven't done much testing yet) I found leaving it off worked better. Especially turning full lock, where you can put a bit of right foot in to pull it around.
    So I still managed to need to winch myself a few metres up out of a bog hole before all 4 wheels stopped spinning. You have to experiment and work out what does and doesn't work!
    Worth it? I'm impressed. It is that little extra something that gives an edge over a standard 4b and allows you to go further - and get back.
  11. The Following 3 Users Say Thank You to P4trol For This Useful Post:
    Bigcol (31st December 2013), MudRunnerTD (31st December 2013), Patrol-Guy (31st December 2013)
