Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: GQ Auxiliary tank and long range ok?
    Oct 2011
    Essendon
    Hi guys,
    Been looking at installing more fuel capacity with a view to a couple of long range trips in the planning for the next couple of years (lord knows you can never have too much fuel in a TB42E). I intend to try and pick up a second hand LRA 75L aux tank to go with my existing 147L long range one. Are there any issues I need to be aware of?
    It seems that there are a couple of different ways of doing the install and the one I prefer is to have one supply and return from each tank rather than pumping from one to the other. Any thoughts on this method? Does anyone have any installation instructions (from LRA or similar) that I could follow or get some ideas from?
    Cheers,
    Drew.
    PM sent Drew.
    My aux was $700 for my 75ltr Aux tank installed while I waited
    That was the system in my T*&^%PY just press which tank you want to use
    Oct 2011
    Essendon
    That's a good price! Thanks mate, just replied to your pm.
    Tip tip tip......tap tap tap....
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    PM sent Drew.
    Where abouts from mate? if you dont mind me asking
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  5. #5
    Re: GQ Auxiliary tank and long range ok?
    TD, something you may be able to help with.
    The patrols have a fuel pump upfront. So am I right is saying all we need is a pick up / level sender and a solenoid to switch between tanks?
    Owner of
    Westy's Accessories
    Oct 2011
    Essendon
    Kallen, I think you need a 6 way valve or something....
    There's not a lot if info about on how to pull it all together out there on the interwebs
  7. #7
    Quote Originally Posted by Drewboyaus View Post
    Your spot on there mate. A 6 way valve though.. I might need to do more digging. Havent read that bit. But I can't think why either. Maybe someone could explain a bit more..
    Owner of
    Westy's Accessories
    Oct 2011
    Essendon
    I think from the bits I have pieced together, it allows a fuel supply and return line for each tank so you can pump from either one. Otherwise you have to pump from the aux to the main tank which looses some of the benefit of having the two tanks (better than carrying a bunch of jerrys but not by much).
  9. The Following User Says Thank You to Drewboyaus For This Useful Post:
    BigRAWesty (13th February 2013)
  10. #9
    Yea good point. I'll dig some more
    Owner of
    Westy's Accessories
    I think your trying too hard Drew. As 3Dogs stated the Tojo is a Completely different setup. From factory their fuel supply allows the engine to be supplied from either tank. when on the sub you are literally on the sub tank.
    The Nissan setup is designed to only draw from the rear main tank. the Sub tank sender has a Transfer pump in it that transfers to the main tank. You will need a dual filler neck and a individual Breather for each but the transfer is done via a pump to the main tank.
    Simple enough and effective.
