Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: Quality trailer hub, brake and bearings
    Thomastown, Melbourne
    6 Post(s)
    Over loaded mate...I know I know!!!
    You or the trailer???
  2. #12
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by Bloodyaussie View Post
    Hahaha, The trailer was I needed to be ......
    ________________________
    ______ 2017 D-Max _______
  3. #13
    ACT
    OK, I'm measuring my axle so I purchase the correct brake and hub but I'm a bit confused where to measure it. There's 39, 40, 45, etc,
    Is this where I need to measure it. I have 40mm in this section
  4. #14
    Benarkin QLD
    Take your old bearing into a bearing shop,trailer shop they will be measured and youll get the right replacements first up ...
    A trailer here i wanted to go from holden wheels to ford, the bearings and hubs are a mix of the two,as the axle diameters are different
    Goin to a 4x4 wheels, i think from memory there a bigger axle again and a flat not tapered bearing as its better for load,but being a wee trailer like that ,with brakes whats its total load ,tonne ???
    You could even clean up the old bearings, and get the part numbers of them,but IF your changing hubs to a different bolt pattern,your best to go into theses places
    2 hubs and bearings for the trailer above, over 3 years ago,was just over $80 ...
  5. The Following User Says Thank You to MQ MAD For This Useful Post:
    Maxhead (11th February 2013)
  6. #15
    ACT
    Quote Originally Posted by MQ MAD View Post
    ATM is only 750kg so brakes aren't needed but the handbrake is bloody handy so I'll put mechanical brakes back on....electric is an overkill for the current setup but if I upgrade then I'll need them .
    I'm pretty sure its a 40mm square axle so legally I'm limited to 14" wheel diameter and it has 16s on it now. I think I'll need to change the whole axle/hub/brake if I want something stronger. If I just change to a bigger hub the axle is still underated and a weak point
    decisions decisions
  7. #16
    Yeah that would do it. Any trailer/ebay shop will have hubs with electric brakes, BUT it will
    still have holden/ford bearings. I specified I wanted 6 stud hubs thinking they would be stronger,
    BUT nah just Holden/ford bearings. Maybe not worth the trouble of sourcing bigger load bearing,
    bearings, I wonder what the more $$$$$ camper trailer use, wouldn't it be funny ha ha if they
    used only holden/ford bearings, weak link there eh
  8. #17
    a member of the menagerie MC97GQ's Avatar
    Jun 2011
    Nimmitabel in the deep, deep south of NSW
    Kris,
    If you are going 6 stud hubs you will need a 45mm diameter axle, you are probably better off to find a trailer shop and get the whole axle, bearings and hubs all ready fitted up then come home and bolt the whole setup to your springs.
    Can't help with the brake side of things, but a good trailer shop should point you in the right direction
    Good luck with it,
    Mark
    Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
  9. #18
    STD backing plate measure centre to centre both ways take a pic plus old bearing sweeeeet as
    If you only want to change from 5 to 6 stud just but new hubs, If you feel you need 50 x 50 solid axle
    measure from hub to hub where rim hit hub allow for off set and tyre bulge. it may not fit under your
    guards, My last trailer only just fit 285s
  10. #19
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    I can tell you that Jayco uses a mixture of Ford & Holden, I contacted them to check and they confirmed it. Ended up having Ford in mine.
    Jack
    2024 Isuzu MUX
  11. #20
    $40K for an off road/ top of the range trailer running pissy little bearings,
    Not this little black duck, would be interesting Thread
